Posted by: dnoce73914 Apr 20 2010, 12:42 PM
Does anyone have a picture of the transmission ground strap installed? I am having a hard time determining where the contact points are.
Posted by: dlee6204 Apr 20 2010, 12:49 PM
You can see where it is bolted to the underside of the trunk floor in this picture. Upper right corner of the picture. (ignore the relay)
Posted by: SirAndy Apr 20 2010, 12:52 PM
QUOTE(dnoce73914 @ Apr 20 2010, 11:42 AM)
![*](style_images/Howard/post_snapback.gif)
No pic right now (i'm at work) but one end goes to one of the bolts on the end cover and the other to a stud on the bottom of the trunk floor.
The stud is above the center of the tranny towards the rear end cover. The strap is pretty short, 5" maybe ...
![shades.gif](style_emoticons/default/shades.gif)
Andy
PS:
Posted by: dnoce73914 Apr 20 2010, 01:02 PM
QUOTE(dlee6204 @ Apr 20 2010, 11:49 AM)
![Attached Image](http://www.914world.com/bbs2/uploads/post-5956-1271789278_thumb.jpg)
Thanks you all for the reply, so fast too! I am new to the site and loving it already. i have a 1973 1.7 and am finally getting back to working on it. I have installed the Bosch hot start kit to no avail. I know the starter is good so I recently discovered that i couldnt discover a ground strap. Going to try this tonight. Thanks again.
Posted by: biosurfer1 Apr 20 2010, 01:15 PM
Good idea...not having that ground strap can cause some weird things to happen...one less thing to wonder about if its installed correctly.
Posted by: underthetire Apr 20 2010, 01:34 PM
You need to clean that
Posted by: dlee6204 Apr 20 2010, 02:30 PM
I KNEW someone was going to say that. That picture was taken when I first got my car. You better believe that thing is clean now.
Posted by: Eric_Shea Apr 20 2010, 03:34 PM
I went crazy with mine and cleaned it and taped it off before I shot the Wurth. This has to be a good ground:
![IPB Image](http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1110-1271799276.1.jpg)
You can see the stud in relation to the tranny mounts better here:
