I bought this as a stripped down rolling chassis. The sller put wheels on it to get it on the trailer. That was 4 long years ago. I also had a son at the same time so working on the car has been a second priority. Now the engine is in and the brakes are on, I should be able to get some work done more quickly. I plan on firing this up within the next couple of weeks and taking on a drve by the end of July. I got the 3m adhesive today to get the fenders bonded on and then the fun stuff begins. Hope to get it completed in time for next years West Coast Ramble. Thanks to the support and motivation of the 914World.
Keep on making progress
I know how that goes....
WooHoo!
I forgot to add the picture
Another view. I love the look of the 17" wheels.
Wow, you have a harlequin car.
Glad the adapters worked for ya! have fun
I couldn't find all the parts in the right color. It wasn't too long ago that Conedodger set me up with the blue hood. The original color is on the longs. I am not sure what it will end up as, but my 4 year old(in the avatar) wants to paint it yellow.
Very unique color scheme.
Now keep goin'!
I thought the decklid I gave you was Signal Orange or Phoenix Red???
Glad to hear it's coming along!
Just for the record, 17" wheels do fit with the AA wheel adapters. They are 17x7.5 up front and 17x9 in the rear with 205/40 and 225/45 tires. There is only about 7mm of clearance on the inside of both. First drive will tell for sure if they work.
That will be a killer looking car whatever color you paint it.
Keep posting pictures and progress.
John
I am leaning toward a color I saw on a scion. It is a blueish gray color. It is kinda a pastel color. If I see another one I,ll post a pic to see what ya'll think.
..Are you going to take any photos of how you are putting the glass fenders on and stuff ?? Please do!!
Yes I will be taking pictures of the flares as they go on. I will be using the 3M 8115 panel bond adhesive and filling the gaps with body filler with the fiberglass strand in it. Then I will put on a smooth coat of regular filler to finish. I havent done any body work since 79 so this should be fun.
I was looking at an old set of axles I have and I noticed the papergasket in the cv joint to hub. Where do you get these? Also, the throttle cable I got on ebay 3years ago separated in the middle at the steel peice that attaches to the firewall tube. Is there a fix or do I buy a new one? I thought about using shrink tubing to hold it in place, but if the throttle sticks I am in trouble.
Careful. Yellow is a very slow color for 914's
Looks like it's a hot car though. Signal Orange or Tangerine.
Dang it's amazing how many different 17 wheels sizes there are for boxters. My boxter wheels were sold to me by a dealer as winter wheels. They are 7x17 et 55 with 205-50-17 and 8.5x17 et50 with 255-40-17. what thickness spacers did you use? what width are the flares?
Maybe you should dare to be different
I know that Scion color you talk about very well. I really like it. Reminds me a lot of the splitty panel bus's
The more I think about it that blue would look pretty damn good on your car
Someone needs to photoshop that for you
Yes Scotty! That is the color! You would not happen to know the #'s for that would ya? It would be cool to photo shop that to see what it could look like.
I agree, that color would look sharp on your car. Keep us up to date!
wooohooo!!!! After some help finding a thread from Andy the car is running!! Now we can start on the shift linkage. I still need to fine tune and adjust the carbs, But it is real close to where it should be. Starts on the first try every time! My wife was even amazed.
Ok, more progress after regress. The mentioned defective throttle cable is being replaced today. The biggest setback was the rear paasenger caliper aftersitting too long seized. I am glad I double checked these things before my first drive around the block. I now have the rear calipers rebuilt and have read the thread on how to adjust them. I was unclear on which direction to turn the adjusters to move the pistons. I know the inner one is the opposite of the outer. To extend the piston out, do I turn the adjuster clock wise or counter clockwise (on the outer piston)??
I figured it out on my own. The outer you turn counter clockwise and the inner is turned clockwise. seems too simple once you do it. The Haynes manuel did not specify turning direction either.?.
Looking good, that would be nice to see the car done in the same as the picture of the bus.
After a final check this past week. The car was driven under its own power for the first time in over 11 years. Since there are no lights or seat belts, among many other parts still missing, I only drove it out of the garage and down to the street and back in the garage. I did this several times . What an awsome feeling! And it feels real smooth. I can't wait to get it ready for the real drive. Now it is on to body work.
I decided I would get some of the pics up of the progress I have made the past few weeks. I will do a more detailed "how to" later and cover the steps better. Not hard to do if you follow instruction well. Solid as a rock!!! Should be easy to fill gaps. Last pic is after the edges were smoothed out. Next will be the kitty hair filler.
Couple of different angles. It takes about a tube of adhesive per flare. I left a huge area in front and in rear of opening to bond to. You could use less if you cut down flare more than I did.
The drivers side before taking off excess glue. Fronts are next!!
Just a couple more angles. The flares from QRS seem to fit well. It made the final bonding easier by spending many hours getting the fitting correct. I also took everything down to bare metal and then cleaned all parts with a degreaser and wax remover. A thin layer of adhesive to cover bonding area on both surfaces making sure to cover completely. Then used self tapping screws to secure. I let each flare sit a minimum 24 hours before removing screws.
Since it has been raining I decided to test fit the rear bumper I have. The question I have for those of you with fiberglass bumpers, is this supposed to be notched out to fit the area below the tail lights? It has the notch to fit the side, but the metal has two notches.
I guess I should say that I will not be bonding this on. I also will be glassing the outer pieces to match the flares. It looks like I need to trim the entire top edge about 3/8" to get a better fit??
Had some nice weather and a few spare hours so I made a little progress. The kitty hair is great stuff! It applied easily and was easy to sand. The final thickness is about an eighth inch.
I don't use kitty hair for the final skim coat because it is so porous. Rage goes on a lot smoother and doesn't show as much shrinkage over time as the strands in the kittyhair. Shrinkage is your main enemy on fg work. It is good stuff though and is waterproof they say.
I am using a final coat of a thin putty, cant remember the name, but it is a 3m product. I will post more pics after final coat of the glaze, putty, whatever it is called.
Don't try to use the scratch filler to replace a good regular filler though. Most of the scratch fillers are really thick paint and if the product is put in too deep of a spot it will shrink later.
make sure you seal up the underside of the fenders so water can't get in there. i had fiberglass gt flares on my car before going to metal. i never sealed up the underside and water made it's way in and caused rust induced seperation.
Dodging rain today long enough to bond front fender on.
One side left.
Last fender bonded on!! The car is starting to look like I wanted it to. Unfortunately a piece of metal got past my safety glasses and scratched my cornia . I will have to wait a few days to get more done.
Cool to see some more progress. Are you going to match the contours of the rear 916 bumper to fit the flares? What kind of rocker panels you going to use? Keep it up.
Cheers
After smoothing down the edges there is very little filler work to do. My eye is healing well, maybe I can sneak in some work today!
I'm betting that will need to be filled all the way to the door jamb edge to look right. Also don't let the eye get infected or the eye might cost what you will pay someone else to do the work, be careful and keep it up it looks good.
If I were trying to do this application, I would use a light coat of short strand kittyhair then after feathering it down, a light skim coat of rage, either gold or extreme to try to keep the shrinkage to a minimum. It will take a few years to find out if you do a good job --- or not. All you can do is your best though. Good luck. I've never had a perfect long term good result with sticking fg to metal over a several year time frame but adhesives have come a long way.
Well it has been awhile so I thought I would give yall an update. First off, scratched cornias suck , I was unable to work on the car until mid June. Next time I listen to the doctor . Ad a two week family vacation to the northern Oregon coast and that wraps up most of July. I have recently added a headlight switch and started back up on the body work. Thanks for the advise on using the Rage extreme filler. Works really smooth. I also welded up some brackets for the front bumper and started fitting both bumpers to the car. Here is a new picture to show some of the progress.
I should post this in the slackers thread. I spent last Saturday pulling the heat exchangers and building a bracket to mount the boxster muffler. I will post more pics when I take out to paint the bracket. I also need to sort out the connection to the engine. Would there be any disadvantage to using the later model 2.0 exhaust manifold spun around and connected directly to the muffler? (Besides the lack of heat).
I thought I would give a quick update. WCR is coming quick!! Here is the boxster muffler installed. I used the 2 ltr manifolds turned around and 1.75" pipe all bought at a local parts shop. I will have this welded up when I can drive it to a friends house who has a better welder. The sound is great. I should add that the total cost for the exhaust was $150.00.
Well, its back on jack stands and I am getting ready to get it all in primer. Doors are off and I am determined to get it ready to paint this winter. The doors are getting sanded and ready to fill small areas of concern.
The past two years we remodeled the old house to get it ready to rent and bought a new house with a three car garage. That was my only requirement to move. Now we have settled in I plan on getting this ready to drive asap.
Starting to fabricate flares into the bumpers. Using foam cores as a trial run. I will blend the rear as it is in first pic into the flares in second pic. Making progress in other areas as well. Getting ready to install front sway bar.
After forming the foam and coating with bondo its time for glass work.
Started on rear bumper today. Two step process. First was making flares off foam mold, then molding flare to bumper. Seems to be going well so far.
Few rough patches, but not bad for a rookie like me.smooth it down add a little filler and we will see.
Ran somE 40 grit over it to smooth out. I have some thin spots to redo and work on the back side. Gotta keep moving
I am really liking the way this is heading. Time for little league, more work tomorrow.
After attempting to get the rockers to line up I decided to try something different. I used the GT rockers do the mold and made ends to go on the metal rockers. What do you think? It is already closer than the glass ones.
Used foil tape over the fiberglass rockers then glasses over. Popped right off when cured.night
I am installing front sway bar today. Should I grease this plastic bushing? If so, what type of grease?
You should make a mold off of those rockers. Odds are you could sell plenty.
I really like the looks of the exhaust. Just seems right to me.
I've done a ton of composite work so I know what you're going through! I happen to like it... Just wanted to say:
Keep up the great work!
Thanks. I have learned way more than I thought I would working on this car. Need to get it finished so I can enjoy it .
Measure 10 times, shave off a little at a time.
I see you are doing the 240sx conversion. I was working on mine today and maybe you can use it as a reference.
I hate to do bodywork but that's what I was doing today. The downside of my installation it is if you hit hard the ground with your bumper....it will crack.
Here is the car with them.
Today bodywork....slow progress toooo...
Keep going, looking good!!!
Looks great. I had already been checking your build thread for ideas.
Fantastic progress Randy!
Thanks Rob. Life is getting simpler, more time to work on my project.
Thanks for all the pictures you took mate! Make sure to update the thread weekly please, I love watching someone make progress!
solid job and soon you'll have the bad boy hot lapping...
