I'm starting this thread for people who need reference or a guide to install some of the parts that we produce. We will be making how to videos also that will be posted on our youtube channel.
We bought this car off a member here, Enhoover.
When we received the car we stripped it and built a rotisserie (plans for these are available).
We removed the right rear quarter panel to better illustrate some of the installations that will be done.
Here is the car right after we got the rear quarter removed.
the rotisserie we built
off to the blaster
looks like mine !!! care to donate any parts
Now that we have the car back we can start to install some of the parts that we produce.
we will be starting with the clam shell stiffening kit we sell.
We painted the car green so when we bring the car to shows it will stand out.
there was front end collision damage that was repaired at one point, so we will have to redo this properly.
we will also have to install floor pans, rear trunk floor, left rear quarter and the front trunk floor
What a great idea. Looking forward to seeing this all happen.
I agree that this is an excellent idea.
Looking forward to watching this.
John
Petey, how about an entire new chassis that we can just move our tags over to?
This is going to be great to watch!
At the end it needs to move to the Restoration thread area.
Is this Rotisserie simply a roll the entire cage over on its side and upside down or is there something I can't see?
Waiting on the next edition!
How 'bout showing us the presses in action - how you make the parts?
and yes to complete bodies!
...agreed.
What they said;-P
This can only help the end user because when you (the manufacturer) start installing metal, you will identify design tweeks to make them better and easier to install. Like the Engman kits that progressed over time through many iterations. And somewhere in the build process you are going to say to yourself "dang, I wish someone made this replacement master cylinder/pedal floor area". Then you will!
Hi Pete...
Perfect timing. My brother just placed that big order for the sheet metal this past week. Time to &
.. I'm sure this will help in some areas.
Any plans on installing the R/R inner control arm mount on your car?
WOW!
This is perfect timing as I will be doing my floors, and many other parts.
Looking forward to seeing this unfold and learn at the same time.
Thanks PETE!
Ya for sure we will find areas we need to tweak, and then we will make improvements. If the pedal area get more demand, that is a possibility in the future.
Plus one for me.
I had to buy a used one for my project.
Here are the drawings for the rotisserie we made.
Rear hoop
Front hoop
close up of horizontal tubes.
Installation of the frame stiffener
https://www.youtube.com/watch?v=IVrmUHRfbCs
Hi Pete,
We ( being my brother & I ) received all of the new metal to do the repairs on our cars. It was a fast order to receive even with all the tins. I must say a job well done at your end. I have a question on the stiffener kit install. Can they be installed w/o having to cut off a portion of the rear lower fenders ?
I plan on doing the install within the next month.
Thanks for adding the videos.
TIA.
Subscribed.
Man, Pete your fast .................. LOL.
Nice work ................
Well done.
Might want to put the frame stiffener overlay on your website....I can't find it.
D your guys make the piece up front on the long that goes over the long and under the front fender?
Rich
Sorry for the ignorance but are the frame stiffeners an alternative to the "Engman kit" or would you do both? It depends on the application I'm sure.
We just completed replacing the front and rear floor pans as well as the seat mount reinforcement pieces and the peddle cluster bracket.
I will have another installation video up shortly, but here are a few photos of the process.
Here is the prep work before drilling out the spot welds.
After the spot welds are drilled we have to chisel off the edges of the pan.
You can see all the rust that is hiding between the pans, so when someone tells you their car is "100% rust free" you know thats BS.
Test fitting the front pan.
Holes punched in the pans for rosette welds
Boths pans and jack points being test fit with butt weld clamps in the middle. The seat mount reinforcements have been spot welded in and the peddle cluster bracket was located with the peddle cluster. The holes were drilled then the bracket was spot welded in also.
Heres the finished product.
Here is our latest installation video...
enjoy
https://www.youtube.com/watch?v=3kMOMNhxg-A
We have updated the YouTube channel with another video of a rear trunk installation.
We also have made the rear trunk reinforcement that lays over the transaxle cross member mount. This new part is P335A
check it out and enjoy!
https://www.youtube.com/watch?v=GBmJkP8I_rI
This is great, i really need to do something about my floor next. Thank you
We put together another video for your viewing pleasure.
Adam demonstrates the installation of the seat hinge risers and the hinges.
If your interested in the cooling gel used in the video, it is a wurth product. Spray it on a nearby location and that area will not heat up. There are some youtube videos demonstrating it in use. Pretty amazing stuff actually.
http://www.wurthcanada.com/media/en/documents/catalogues_and_product_info/newproducts/03.2012%20-%20Protective%20Welding%20Spray%20&%20Paste.pdf
https://www.youtube.com/watch?v=PWgt8AaqnUI
I agree with most on here that this came along just in time! I am doing a passenger side floorpan replacement very shortly!
To fix this mess:
http://s171.photobucket.com/user/Sleepin1974/media/Erics%20914%20New%20Paint/50ca95a0-1b58-4001-b7b3-1f600dba25ba_zpsc3e0a4c0.jpg.html
Does Restoration design make anything for the cowl/fender seam? My passenger side is also in bad shape.
Currently we dont have any repair piece for that seam. If you have rust in there, it probably goes deeper.
You might want to get a piece from a donor car. Make sure you get all the rust or else you will see rust coming to the surface again in a couple years.
We have shot a few more videos of the green 914, but I wanted to put this video up first.
A day in the Life of Restoration Design.
https://www.youtube.com/watch?v=C6CEx0UB8FM
Good to see that you guys are doing well. Always a pleasure to order from you.
Nice piece of Canadiana. Where the heck did you get that tractor? It's a beaut!
Love you guys!
Pedal cluster panel next? Soon? Maybe?
Wow. I just noticed that you make the rear trunk reinforcement piece so I ordered one. Thx Pete.
Thanks for the updates...I've bought your metal and it's always top shelf!
When will the new complete body shells be available??? I've seen complete new Mustang body shells online ( 64 - 78 models) for $15k. New. Just a thought....
These are awesome! Wish they were around when I started tearing into my project...would have saved me some headache for sure...
Can any of you gents direct me to a thread with a comprehensive front quarter r&r with pics?-Guy
So you only ship one thing a day?
Seriously though...thanks for making the awesome stuff you make.
We have made another video for the installation of the suspension console.
Adam fabricated a jig before he cut out the old console to ensure that the new one was put in the exact same location.
https://www.youtube.com/watch?v=v40ZpRL1Osw
Here is a diagram of the rear console specs taken from another poster on the 914world. I don't recall who initially put it up, but thank you.
Nice Jig! So you told me once- the steel you use is treated to prevent rust? So the inside of the ears should be good to go? Adam stated he used POR? IMH opinion there may be better rust treatments, the Eastwood products as example, but possibly the experts will chime in.
This is great stuff guys! My driver floorpan is like above, with a hole. The seat bracket also rusted and broke on one side. Is it possible to do floorpan repairs without pulling the car all the way down and putting it on a rotisserie?
Also, looks like you guys need a Porsche tank to go with those tractors. I think Bovington in the UK has a King Tiger with the Porsche designed turret...
Hey Pedro, where do you guys buy your galvanneal from? I'm curious if it's a Dofasco product.
Hi Pete,
How's the progress on the lower engine firewall coming along?
BTW, I like the videos of the new metal installs.
Have you guys ever considered renaming your business to Rustoration Design? Maybe as a joke on 9/14/2014?
I love your parts and videos but Please consider wearing sleeves when you weld. I had a friend develop melanoma from tacking without gloves. They took a finger, then his hand, then his arm to the shoulder before the cancer finally took his life.
Please continue supporting our little cars. With your parts our cars will last generations.
Pete, you are the fricken MAN! Always good to see you and your work at Hershey.
I love watching your videos to see how this is done. Very informative. Thanks so much.
It would be extremely cool if you guys actually did make a chassis in white for our cars.
I bought a third of a car from your original owners and the quality was 110%. I recommend you all the time. If you are in Dallas -Ft Worth you need to stop in at Zims. I argue with them about your quality but they keep ordering from some guy in Denmark (356 body parts).
One day......your new 914 body....
I appreciate you guys taking the time to produce these videos. Top notch! I also hope it creates an additional sales jump. Companies that produce good quality, affordable parts for our little cars are getting scarce.
Hello All!,
Thanks for all the positive remarks. We are glad to be able to provide these videos to give a little bit more instruction on how to install all these pieces.
I have one more installation video of the battery tray and support. Enjoy!
https://www.youtube.com/watch?v=6ExKXK0UXpI
Over 110degrees outside in the pic below
Thanks for the design guys! I added a few inches to the mounts to raise the shell, maybe not a good idea but fixable if it makes it harder to roll over? Not finished welding yet, need more bracing! but for now it is fine as it sits. This is my 'bad' shell that has holes EVERYWHERE and was used just to test fit. The nice shell is in the garage
Changed it up a bit other places too:
41" horizontals
25" diag/vert mitered all 22.5degrees. I was thinking of having some 135deg gussets made on a waterjet/laser/plasma somewhere.
107 1/8" connections.
1/4" plate mounting.
Link to more pics.
https://photos.app.goo.gl/H4bwWScZuNJN89N68
