In between watching the crummy coverage on CBS of the San Marino Grand Prix, I installed Boxster monoblock brakes on the 914.
Another view.
Last one.
show us the adapters please
BTW - what do 4 boxster calipers go for lately?
I'm cured! I actually have (nearly) a full erection!
M
The adapters are shown in the photo. I think that they are available separtaely from Racers Edge but I bought a package from Paragon Products (talk to Jason). You wouldn't want 4 Boxster calipers - just the fronts. I am using Carerra rears.
So you used Mueller's adaptor hub thingies with the Boxster kit? MORE INFO PLEASE!! Woo!
I plan to buy a set of these as soon as eComm goes up. I was looking to do the same thing you're doing.
Cole
QUOTE (wrpspddrvr @ Apr 24 2005, 08:06 PM) |
So you used Mueller's adaptor hub thingies with the Boxster kit? MORE INFO PLEASE!! Woo! ![]() ![]() I plan to buy a set of these as soon as eComm goes up. I was looking to do the same thing you're doing. Cole ![]() |
QUOTE (Aaron Cox @ Apr 24 2005, 10:08 PM) | ||
wrong. bolt spacingss are different. boxster kit is also 1 grand.... and you need 911 3.5" struts..... so your better off going a whole 911 front suspension... |
QUOTE |
Damnation. I swear I saw some adaptors to fit a 3.5" caliper on a 3" bolt hole spacing somewhere.. |
Aaron's right, you need 3.5 inch spacing to fit the adapter. Early 911 struts have this. The Boxster calipers fit Carerra rotors. In Aaron' s case he already has M brakes so he has the proper spacing.
Righ Johnson sells a complete setup for all for corners
Why would you not want four boxter calipers?
I have all four on mine
QUOTE (slivel @ Apr 24 2005, 08:25 PM) |
Aaron's right, you need 3.5 inch spacing to fit the adapter. Early 911 struts have this. The Boxster calipers fit Carerra rotors. In Aaron' s case he already has M brakes so he has the proper spacing. |
I should have been more clear in my response - you wouldn't want to use the fronts all around. If you have the complete set of fronts and rears then you are fine. You will probably need to go with a 23 mm M/C though.
Aaron, yes you are right again. My mistake - sorry. 3 inch for the M's.
QUOTE |
I should have been more clear in my response |
I've done the 986 F & R caliper install on 2 sixes last month, with the 19mm mc...with a noticeable braking improvement. I know of one 9146 with 986 rear calipers all-around, and the owner (Dave @ TRE) says it's the best set up for his street/ track car. I still prefer the F and R set-up. I'll prolly go to the tilton or wilwood proportioning valve next.
are the Boxter rotors different? or do those calipers work with the same 911 rotors?
The Boxster calipers work with standard 24 mm Carrera rotors.
