Printable Version of Topic
914World.com _ 914World Garage _ Alternator Gasket 022903203
Posted by: bobboinski Sep 5 2019, 07:15 PM
I am looking for the gasket that goes between the alternator and the alternator tin/snorkel on a 1974 2.0. Got the part number from the local Porsche dealer but NLA.
It is a VW number 022903203. Searched but no luck. Hopefully I just did a crummy search. Any help greatly appreciated.
Posted by: IronHillRestorations Sep 5 2019, 09:57 PM
I just got some thick gasket material and cut my own. I also glue a piece of the gasket paper to the rear metal cover plate where the positive terminal connects, just for little extra insulation
Posted by: jcd914 Sep 5 2019, 09:59 PM
I would check if 914rubber.com has them.
Jim
Posted by: bbrock Sep 5 2019, 10:04 PM
QUOTE(IronHillRestorations @ Sep 5 2019, 09:57 PM)
+1 I did the same. Somebody on the Samba posted a template you could print but I couldn't get it to scale right so just used the cover plate and a compass to mark the gasket material.
Posted by: sixnotfour Sep 6 2019, 02:50 AM
from samba
template for alternator gasket 021903637 / 021 903 637
Print out at 300dpi and you're good to go.
Posted by: sixnotfour Sep 6 2019, 03:08 AM
https://www.malcolmengineering.com.au/vw-kombi-alternator-seal
Posted by: bbrock Sep 6 2019, 07:31 AM
QUOTE(sixnotfour @ Sep 6 2019, 02:50 AM)
from samba
That's the one I tried but never could get it to print right on a Windows machine. Spent more time fiddle farting with it than it took to just use the cover as a template. Maybe it works better on a Mac?
Posted by: bobboinski Sep 6 2019, 08:07 PM
Thanks for the replies! I think I will try to make the gasket. Don't want to wait for shipping from Australia but at least someone makes it. Didn't show up in my searches. Thanks again for all the help, this is a great place.
Posted by: Spoke Sep 6 2019, 08:45 PM
Here's a simple gasket template I made with Powerpoint. The Powerpoint file is below. It has 2 concentric circles with 3 through bolt holes placed 120 degree apart from each other. I printed this then with a razor knife outlined the shape on a piece of gasket material and cut it out with scissors.
Attached File(s)
Alternator_Gasket.ppt ( 101.5k )
Posted by: porschetub Sep 7 2019, 02:26 AM
Use some JB weld black silicone ,IMO its not a place for a paper gasket the original I always find not seating properly anyway.
Posted by: bobboinski Sep 7 2019, 09:10 AM
QUOTE(porschetub @ Sep 7 2019, 01:26 AM)
I was considering silicone.....
Posted by: bobboinski Sep 7 2019, 09:20 AM
QUOTE(Spoke @ Sep 6 2019, 07:45 PM)
Thanks for the link. I'm going to be working on the engine tomorrow, hopefully I get to this point in reassembly. There appears to be quite a difference in the Malcolm engineering gasket and the templates.
Posted by: porschetub Sep 7 2019, 03:44 PM
QUOTE(bobboinski @ Sep 8 2019, 03:10 AM)
The stuff I used handles the heat also,cheers.
