I want to make a good showing at my first SCCA National Runoffs so I decided to upgrade my backup engine. (I don't have a real race engine right now.) I'm installing my 94mm Nickies set
and the JE pistons with stock dome shape.
*Drool*
Chris - I held the first EVER set of Nikkies, they went on Shad's car - I help him build his motor! They are amazing pieces of equipment. Very light!
And you do nice exhaust work too, my friend...
Later,
Tom
I got some stainless valves and decided it was time I started learning how to port my own heads.
I'm having a lot of fun doing this.
It's important to know where NOT to remove material
Oops! It's a good thing I know a talented welder
Nice stuff!
Let's see, the Runoffs are in about two weeks at Mid-Ohio right? I'll bet there are a few club members in that area that would be willing to help you push that thing off the trailer.
Chris,
Tell me about your fan set up. I've read the discription on you website, but what are the advantages?
More air?
Lighter than the stock fan and housing?
Drains less HP?
What gives?
Wish I was going to the Runoffs. Good Luck!!
Paul
The more I see guys tearing their engines apart, the more I think, "Gee, I could fail at that!".
I like the hz cooling, do you know of anyone with it on a 914/6? I have a friend with a 935 that has it, but it's crammed in there with too much other stuff to imagine it fitting in a 914.
M
Good luck, Chris.
What class? gt3?4?5?
chris,
When you run without the alternater is just a matter of taking it off? There is probably 20 pounds there. Do you run a racing dry cell long life battery?
Paul
F Production. There are 5 914s entered this year, out of about 38 cars. Three of them are from my division (Northeast).
The alternator is long gone. I don't have much wiring in the car Paul, no relay board either. The car starts with the same column mounted key switch that the car came with. I cut down the stock fuse panel to 3 fuses and mounted it in plain sight on my auxillary gauge panel. The fuel pressure and oil temp gauges are mechanical. The only significant draws on the battery are: starter, fuel pump, ignition and brake lights. I have been using a Pertronix and Bosch blue coil, but I'm switching to a Mallory Unilite with Mallory coil. I've heard that MSD type ignitions don't like running on low voltage. My voltage is typically around 11v, except right after a recharge.
The battery is a regular 914 battery (group 42?), mounted inside a marine container. I have a big grey disconnect on wires from the battery that hooks up to a connector on my charger. I usually run the charger for 15-30 min after each on-track session. I killed the battery at a PCA autocross one time with two drivers. Too many times using the starter.
I have not replaced any panels with fiberglas yet, still have the stock windshield, and will have 60 lbs of ballast on the passenger floor to meet the minimum of 2020 with driver (approx. 230lb). The car has almost perfect left to right balance now.
I've seen pics (PPBBS last year maybe) of a gear driven horizontal fan for a 6 but don't know much about them, and haven't seen one up close. I did look at the 917 fans at the first Rennsport Reunion. I think the drive shaft comes up through the center of the crankcase on them.
Yep. We ran a FAT 911 upright setup with a gutted 911 alternator and just plug the car in between rounds to the charger. I also learned to take a jump box with me to grid so the car doesnt really use its own power to start when the 2 or 5 minute warning sounds and we need to fire it.
B
I've also striped all the wiring down to the minimum. And I have three fuses in a marine type fuse block. Fuel pump and gauges are all that I run, no brake lights (autox only). I still have the circuit board. If I remove the alt. I guess I could remove the circuit board, but I'd need to keep the voltage reg somehow. I plan on running a dry cell lightweight battery like this one below. I lot lighter (15 lbs) than a stock battery. I'll install some of those quick connect jumper posts like the drag race guys use if I need to start it on the grid.
MSD quotes (8volts) to run their ignition.
We talk about running a battery dead...and some of the drag cars I worked on had 16 volt ignition systems and would drain the 12 volt battery in about 3 seconds when all the Nitrous solenoids and gas solenoids where activated along with a both fuel pumps. Crazy stuff running a 16 volt battery on the ignition system. We had to run a alternator.
B
I finished prepping my heads. The combustion chambers have about 38.5 cc volume.
and installed my special valve springs to check the piston to valve clearance.
The intake valves interfered by about 80 thousandths so I made a fixture to cut reliefs.
Here are the finished pistons. With .040" deck height the compression ratio will be about 11.4 to 1.
look nice!
I temporarily installed the heads and checked the rocker geometry. I ordered a set of custom chrome-moly pushrods 1mm shorter than stock to optimize the valve lift and minimize valve guide side pressure. I am using swivel feet and recessed them into the rocker so there will be some adjustment available.
I thought about using my specially modified rockers, but will probably save them for the next engine.
The ends of the valve adjusters have to be shortened so they don't hit the valve covers. I still have to check the rings to make sure the gap is correct. Then I'll clean everything and assemble. Hopefully the engine will be done this weekend and back in the car before my dyno appointment Tuesday morning.
You should at least knock the casting flash off the other rockers and polish them up.
I see you like to flycut to the point that the combustion chamber becomes one with the holes for the exhaust studs....LOL
Looks great man. Should run like a champ.
B
Hey Chris. what are you using to repair the heads with? Can you use a small Tig for the aluminum? I got one at work and have not tried it yet for aluminum....I do understand that you need high frequency though.....
When you get to the run0ffs, look up Bruce Allen from New Hampshire....He was running as one of my early instructors and now has a new respect for the 914.....He is running formula continental I think.....
Good luck!!! Herb
Brad,
Yeah, I am working on the rockers more today. They will be better looking before long, but I'm not going to lighten them much.
This was my first time filling the back of the stud hole. I don't think I actually flycut deep enough to hit them, but took precautionary measures just the same.
Herb,
You need at least 150 amps of AC with continuous high frequency to make the heat required to weld thick sections of aluminum like heads or crankcases. I have read that some new machines work well with DC current for aluminum but haven't seen it in operation. Aluminum welds so differently from steel and takes mucho practice to do it well.
I don't see Bruce on the final entry list. Only Phil Lombardi from New Hampshire, #33FC.
Thanks.
Chris, have you finished your oil cooler ducting? How about a pic of the finished product.....
Chris,
Thanks for all the great photos. Nice work. Now, with your and Brad's comments, I understand how a deep flycut can get into the exhaust studs. Jake had explained that to me but I didn't really visualize it before.
Best of luck at the run-offs. I wish I was going. A good friend of mine from Virginia is running a car for his son in FV, Bill and Justin Barker, and they wanted me to join their group. I should have planned better!
Mike
Excuse my ignorance but...wouldn't it be better to have the intake ducts lower on the car. I seem to remember that hot air rises. It seems to me that you would be creating undue turbulence with the hot air attempting to exit where the cool air is coming in. Would the cool air ever get to the cooler?
Paul, both those ducts are inlets and in a high pressure area on the front of the car. The primary outlet is directly below the cooler - the two plugs in the floor are removed, as well as the small holes in the front of the trunk which are behind the airdam, therefore in a low pressure area. As far as heat rising, it won't have much choice with the ram-air effect at 100mph.
I'm somewhat constrained by rules, which is why I'm changing the previous configuration in the first place. Even removing the floor plugs may be somewhat debatable as to legality. BTW, I'm not allowed to duct the exit air, or at least extremely limited.
What sorta HP are you getting?
And what is your red line or shift RPM?
Great pixs
Paul
Maf.. this is exactly why I shoot pics. I can talk all day... but to show you is where you will learn the most.
Chris.. I may have a cam for you on the next engine (the cam) you could run the LN lifters against it and build out from there. Your new shift chip will be 8k and you will need much bigger cooler(s). The one you have now just barely cools our stock 2.0 engines.
B
Here's the head being drilled.
The block is ready for the top end assembly.
I think I have everything clean and ready, so here goes!
Are all those pully's and angles for the belt inefficient?
chris, got a picture of your carb linkage installed? what's the brand? looks pretty stout.
kevin
Assembly complete. Installation tomorrow. Dyno Tuesday.
red lion? could it have been red-line? red line is like the west coast weber distributor
Chris.. dont mean to be a nit pick.. but you dont *really* run rubber tranny mounts do you ??
B
Man! It's cool! That looks cool!
M
I gotcha. The Weltmeister plastic crap does suck (they compress too esily). We run aluminum blocks.
Man.. that fan shroud looks COOL.
I'm a little concerned that you dont have enough crank case ventilation. Every EP/FP car I have seen has a huge radiator style hose going into the top of the block and into a breather box mounted in the trunk.
B
Here's a pic of the breather tank
and the return line.
IT RUNS!
I timed it to 33 deg total advance. I don't know much about the Mallory distributor yet so I'll probably have to fiddle with it a bit more.
Great NEWS Chris I only noticed one -10 line at the oil filler area...thanks for clearing that up for me. You nailed the hot ticket.. use the scavenge from the dry sump setup to pull a vacuum on the engine.
B
Looks sweet Chris! Almost makes me miss the Type4 (almost...nah)
So where does one get truly solid trans mounts i.e. the alloy blocks? I was appalled when I ordered "solid" mounts and received these Welt things which are chunks of urethane or something.
HPH stocks them.. or you can make your own from 1.5 inch square tube and 45 degree angles cut on each end with 3 holes..
Nevermind. I'll bring some down for you on Friday.
B
Tarett has em also for $100 a set
Oh yeah.. but they are for a 911. He would have to drill the holes out.
B
