huge thanks to brad/clayton/kevin/joer
well, brad rocks (we knew that)
everyone said when you remove the choke/fuel enrichment circuit, you pull the 2 little springed psitons inside...
WRONG. there are like 15 types of IDF's, and if yours came with chokes, all the choke passages are drilled.....
i need this part badly! my car was a fuel pump.... must have been 1:1 AFR.......
oil change here we come.....
I NEED THIS PART BY SATURDAY !!! PLEASE HELP! ANYONE HAVE PARTS CARBS????
I Mostly just need the "spring clip" at the top, but will take it all if you got it.
Aaron Cox
acox914@comcast.net
I have it.
Show me the exact part.
Or tell me the number...
Or better yet, take a pic.
Rich
i really need at least 1 #61....
and the springs...... under them
I have two parts 44 IDF Carbs...
Is it the same part?
If so, its there...I will go check...
Meanwhile..think about this..
My tranny.. (In PM) I need to put a stock fifth in there...
Look at the gears again and tell me what my shifting will look like...4th-5th...I mean to ask,,,is it doable...
I will go out and look now..
Rich
compyter hard drive got erased by boneheads at bsetbuy....
im trying to find all the files
ill post a thread...
sorry i never got back to you been real busy
i got the parts you need a can go out mon
pm me if ya still need em
james
I got nothing...and its really cold out.
I looked, no part there...
My carbs where empty, and the parts box does not have that part...sorry...
Rich
QUOTE (r_towle @ Apr 8 2006, 07:21 PM) |
I got nothing...and its really cold out. I looked, no part there... My carbs where empty, and the parts box does not have that part...sorry... Rich |
If you are trying to stop the flow...try jbweld...
Rich
Wow man, I'm really sorry about this aaron. I know I told you this. I searched my carbs up and down witha flashlight and couldnt find any passage holes from the choke bowl...
QUOTE (MattR @ Apr 8 2006, 09:49 PM) |
Wow man, I'm really sorry about this aaron. I know I told you this. I searched my carbs up and down witha flashlight and couldnt find any passage holes from the choke bowl...![]() |
Good thing the rings were seated......
Hey Aaron
I got some 40 IDF around that have the things you need .
I can drop them off tomorrow
interesting aaron. is there no way to undo the passageways that i presume have been opened up?
k
QUOTE (craig downs @ Apr 8 2006, 10:33 PM) |
Hey Aaron I got some 40 IDF around that have the things you need . I can drop them off tomorrow |
QUOTE (rhodyguy @ Apr 8 2006, 10:39 PM) |
interesting aaron. is there no way to undo the passageways that i presume have been opened up? k |
can you post some pictures of 54 thru 61? i've only seen the assem while attached. the back side specificly.
k
plugs=cover plates and pistons=leave the assem in place i guess.
k
QUOTE (rhodyguy @ Apr 8 2006, 10:45 PM) |
plugs=cover plates and pistons=leave the assem in place i guess. k |
I just removed the top off and they are there.
If you need em I'm gald to help out
Do you just the clips or the whole thing?
these parts
YUP... Exactly what Morphenspectra shows on the above pic...
Clayton
