I finished my rebuild about a month ago. I've driven my teener for only about 20 miles since. I have a small puddle of oil on the garage floor, which I believe is coming from the small window in between the engine and tranny. I drove it today for a couple of miles, parked it in the garage and it immediately began to drip oil from the above location. I checked my oil and it is about an eighth inch to a quarter inch above the full mark. I guess I over filled the oil. I replaced the rear main seal during my rebuild and can't imagine that this is the problem. It is definately oil and not gear oil. How hard would it be to remove just the tranny and not the engine. I don't think I can go through removing the engine again, but I will if I have too. Any suggestions are greatly appreciated.
Thanks,
Rod
It can be done, it is done, and you can find out how when someone comes along how already has done..
I just wanted to tell you it can be done, hope you feel better.
M
-they are going to say it takes less time to do the whole drop..-
Is it engine oil or tranny fluid? Tranny fluid is thicker and smells alittle like eggs. Sometimes, hell most times, if you pull the motor you can disturb the pilot shaft seal. If its old and hard then voila! Oil leak!
Geoff
Just think of removing the engine as an investment. It only takes me about an hour and a half when I'm not busting ass. The more you do it, the easier it is.
It's pretty easy to remove just the tranny and I've done to change the rear crank seal. Remove starter, un-do driveshafts, chock the rear of the engine so it doesn't hang on its mounts and whip out the gearbox -two gearbox mounts and the three remaining bolts on the engine (starter is one of the four). Don't forget the earth strap! (I always do)
You can lower the 'box on a car jack its not that heavy. Might be wise to get a clutch alignment tool.... I didn't have one and used a deep socket that fit. May as well get a new thrust bearing for the flywheel too while your in there.
Make sure to index your flywheel so it goes on the same position it came off for balance purposes.
-j
while you're in there, check out the oil galley plugs.
Okay, so I was mistaken. The fluid on the floor is thicker than oil and smells nasty. So I am thinking this is gear oil. Can anyone tell me what on the tranny would cause this leak between the tranny and engine.
Thanks
speedo's drive can spew oil, too. Was the speedo working?
Like I said earlier, if you take the motor out chances are that pilot shaft seal if old, will then leak. Pull out the tranny like was said and install one quick. Its pretty easy although tricky to remove the old seal if you don't have a seal puller. Make sure to clean and check the shaft for scratches and burrs so the seal won't just leak again.
Might as well install new tranny fluid while you are at in.
Geoff
Andy, is this the main shaft seal we are talking about? I am having a hell of a time trying to get it out. My seal puller is too big. Any suggestions?
Thanks,
Rod
Try using some picks to start prying it and get it going. You'll never get a traditional seal puller in there. Also, be careful not to score the pinion shaft. Use lots of lube when installing the new one and make sure the inside (part that is against the shaft) is laying flat.
Matt
Thanks, I got the seal off but it appears the PO might have used some type of sealant. It appeared to have been glued on. The portion of the seal that goes into the tranny was very brittle and some very small pieces fell into the tranny. Should I be concerned with this or should I try and fish the pieces out? I have been trying for like two hours with no luck.
Thanks
Make damn sure you check the pivot ball for the clutch fork. I'm to the point now that I check ALL of them when we have the tranny's out. I have been bitten too many times. I pull them out and load them up with some good sealant and screw them back in.
B
I'm pretty sure they were small pieces of rubber so I probably wont do much about it then. As for the pivot ball, I did notice that it is leaking. I will take it off and seal it up. Thanks for the help.....
Andy, does this metal ring have to come out as well, or is it part of the tranny.
Thanks,
Rod (Feeling stupid in Cali)
Andy, thanks for all the help. I got the seal in and tranny in. I used this motorcycle jack and it worked great.
