A few months ago I bought a "Porsche 914 Gas Shock Kit" on eBay from this vendor:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=330219178155&rd=1
I've misplaced the instruction sheet, and repeated emails to the vendor over a span of a couple of weeks didn't generate any response. All I really need are the measurements, say from the taillight lens to the 1st hole, and on the lid side, from the front edge to the 1st hole.
Any help will be greatly appreciated.
Jim
I bought these as well.
Not to bash, but return them if possible, or cut your losses and contact Craig at CAMP914. IMO they are much easier to mount and after you open and close your trunk lid over time, I believe the screws hold up better at the mounting points with craigs. Just my .02, good luck.
I second. Don't do it! And by the way the rear trunk spring rods work perfectly. The rear shocks restrict movement and utility (like swinging the top into the trunk) Don't do it!!!!!!!!!!!!
3 cars I've installed these on ... never a problem ... one 3 years ago .... Now I don't worry about torn from the body hinge brackets or replacement of those stupid rollers and the potential blood. I can put my targa top in the trunk with no problems and with the same effort it took when it had torsion bars. If you're a CW more power to you ... keep dealin' with those idiot torsion springs. With his kit you don't have to cut the seal.
Worried about screws .... spot weld the brackets. Jeeeeeeezzzzzz
I have an internal cable release for my rear trunk. Do these struts pop the trunk lid up, when the latch is released?
I took some shocks off a hatchback at a pull-a-part wrecking yard and fabbed & welded my own brackets. Cost me $5 in parts. Works perfect, still easy to get the top in and out. Glad to have that stock torsion spring outta there.
I mounted the lid/top ends first, propped the trunk up fully open, that told me where to attach the other ends of the shocks. Simple, no instructions or measuring needed.
Mine does not lift the lid as soon as the latch is released... It pops enough to get under it, then I lift the lid a few inches, then the shocks lift and hold from there.
The spring on your rear trunk latch will "pop" the trunk up enough to get your fingers under the lid. You then just start to raise it and the gas shocks will take over with a nice smooth motion ... not a chin busting fly up like the torsion springs.**
** Ok, so I exaggerate a bit.
I made my own using 944 rear hatch shocks. Welded my own bracket and attached the front hinge pin to the trunk hinge bracket. I had to notch the rear bulkhead to clear the shock rod. Not factory but hey, I at least used porsche parts.
No problems with the top fitting and removing the torsion bars cleaned up the engine compartment and gave room for my rear facing carb throttle linkage.
Nice. I mounted my top ends the same way to the hinge bracket.
Thanks, everyone, for your help/opinion. SLITS, special thanks for taking the time to post pics of the directions.
Jim
Kargeek
I was looking at your rear shock support. Where did you get it and does it help?
I just got a set of these shocks that were donated to the Route 66 run by ??(sorry I can't remember) The directions called for cutting the front of the trunk . I couldn't bring myself to doing it so I mounted them in a way that avoided any cutting. They work perfect, top fits in...did I mention no cutting?
Decklid
Trunk still intact The mounting brackets are reversed relative to which goes on the car vs decklid when compared to the "proper" way the instructions called for. But like I said, I couldn't see cutting the trunk for these things. It is never good when the instructions list a hacksaw as required tool for installation.
They do work perfectly installed this way. I wouldn't do it on a FG lid but stock lid is plenty strong.
Smooth move Slick .... I believe those are Boxtsers kits that "require" cutting. The other kit sold on eBay doesn't which is much preferable.
How about the kit that is sold on CAMP914? Does anybody know how that kit installs.
do you notice any difference with that strut tower brace installed? doesnt the rear firewall basically act as a strut tower brace?? been lookin into this
[do you notice any difference with that strut tower brace installed? doesnt the rear firewall basically act as a strut tower brace?? been lookin into this]
Probably not...this was something I picked up 25 years ago at the Pomona Swap meet. Looked Cool, that about all I can say. The same vendor sold a kit for the 911 front strut towers which I'm told there is an advantage.
Some asked about my shocks. 944 rear hatch shocks and the mounts were fabricated and welded to the trunk channel. Yes, with my mounting pin on the trunk hinge, you have to notch the bulkhead to clear the shock rod.
DH
