Home  |  News  |  Forums  |  FAQ  |  Classifieds  |  Events  |  914 Info  |  Blog  |  Members Map
IPB
entry Dec 4 2005, 09:29 AM
Yesterday I worked on finishing up the drivers side brake assembly/suspension then took apart the the other side as I bought a bigger size hub to disc bolts to install. Wrecked the grease seal taking everything apart so I'll have to get another one. Took apart the extra 039 dizzy Blair got and it is a rebuild unit. Too bad it was sitting outside in a plastice bin with 6" of water! Cleaned it up and bought some proper tiny screws to reassemble it as the rebuilder used all kinds of goofy screws with washers to assemble it.
Brand new trigger points too!
I dug out the 73-74 Black door panels and also bought a set of chrome window crank handles so those will go in as soon as I get time.
What I need to do to finish:
assemble right side rotor
bleed brakes
install rack spacer kit
hook up drivers side S duct
install new speedo cable
hook up clutch cable
add oil
add tranny oil
hook up shifter linkage
adjust venting clearance
install battery
install door panels
install speedo
install tires
test run to oil the engine without plugs
install plugs and run it to break in cam (outside)
« Next Oldest · 914World Blog · Next Newest »
0 user(s) viewing
0 guest(s)
0 member(s)
0 anonymous member(s)
Search Engine Guest
My Picture
User Photo
