Southern Rods Condenser, mini evaporator https://www.southernrods.com/out-of-stock-m...--a-c-only.html and Patrick Motor Sports Oil Cooler and shroud. Electric Compressor is a Benling DM18A7. The carpeted trunk board goes over the shroud and condenser. I also drilled holes in the front spoiler to direct air over the condensor. So far it blows cold and then the amps go over 100 amps and blows the breaker. 914toy is running the same evaporator horizontal under the dash and his works fine. He also has 3 condensers. One in front and one installed with fans in each rear fender. Hopefully I will have time this summer to get mine working. ![]() ![]() ![]() ![]()
