Some installation photos of the Weltmeister Rear Swaybar.
While the install acually went very easy, it appears that the if the bar is set to its "full soft" setting that the adjustable slider will come in contact with the shock housing. I guess I will just have to set it a bit stiffer! The next trick will be to balance the front and rear adjustment to even the handling out. The first test of the new set up is next Sunday's AX! Haul Ass baby! Attached thumbnail(s)
