H.I.D. kit took about 2hours to install. Used a pair of Hella H4 E code lens and a hid kit with a temp of 6000k (daylight) the harness on the kit plugs right into the stock plug but I had to add 2 holes between the trunk and headlight for the additional high voltage wiring. The kit draws about 8amps on startup and a constant 3amps. The systems is rated at 35 watts. Look at the difference between the headlight color and the fogs. The fogs used to match the Silverstar headlights that i removed. I love the look, and i will soon be upgrading my stock fogs to H3. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
