Here is the list of what i got: > CDA 9887 Headunit w/ 4volt preamp output X 3 (im gonna use 2) > Phoenix PLD1 Line Driver will feed the 2 bass amps > Phoenix EQ215i Equalizer w/ 15 adjustable frequency controlls for each channel to feed the mid/high amp > Phoenix XS2500 Amplifier X 2 I will be running one of these for each 12" woofer Bridged into 1 Channel @ 2 Ohms rated at 300 watts X 1 Continuous output I also have the LPL44 remote bass knob to control both amps you need adjustment with the top on vs off > Phoenix XS 4600 Amplifier This will be for the component set Bridged into 2 Channels @ 4 Ohms rated at 150 watts X 2 > Phoenix DD5 Desmazes Delayeator This little Baby turns on and off each amplifier and processor it has adjustable delayed fused circuits for the remote and power wires to eliminate any noises when components are turned on or off. (very cool) > Phoenix RSDC122 12inch Woofers X 2 Each woofer has dual 2ohm voice coils Rated at 600w Rms / 1200w Peak > Phoenix RSD 6.5ds Component Speakers 6.5 inch component w/ tweets Rated at 120w Peak The Plan: Headunit goes into the stock position. PLD1 goes in passenger footwell, hidden under carpet. DD5 goes into center console. EQ goes between seats, hidden under center cushion. LPL44 Remote knob mounts to new center console. 3 Amplifiers in rear trunk desigend by Me 6.5 drivers go into fiberglass kicks. Tweets go on the pillars or dash. Woofers go in front trunk w/ another wood/glass enclosure. All of it completely hidden from view. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
