2L core engine, longblock, 1 ea 2L heads 2L short block, core, 3 ea 2L case 2L crankshafts 2L rods 9550 camshaft and matching lifters 94mm pistons and cylinders 96mm pistons and cylinders windage tray with seals flywheel D-Jet AAR, fuel pressure regulator, decel valve, cold start valves L-Jet AAR, fuel pressure regulator, decel valve, cold start throttle body D-Jet 2L intake manifolds, intake air distributors, air cleaners L-Jet 1.8L ntake manifolds, intake air distributors, air cleaners engine cooling tin 2L cooling fan housing +bus relay boards seats, black, 4 ea backpad, black, 73-> door panels black carpet, brown center tray w/cushion, brown x2 console combo gauge w/oil temp 73, 74, 74-76 oil temp sending unit/taco plate alternators starter D-Jet ECU D-Jet 2L fuel injectors, intake runners, intake air distributor, fuel rails MPS distributors, L-Jet & D-Jet L-Jet ECU L-Jet AFM D-Jet 1.7 fuel injectors, intake runners, intake air distributor D-Jet 1.7 oil bath air filter w/stand D-Jet 1.7 air filter elements, 4 ea transmissions 4 ea, 1 rebuilt side shift Dr Evil clinic front hood engine lid with letters, green IMSA front fiberglass bumper fiberglass front bumper GT fiberglass front valance for flaired fenders gas tank with expansion tank x2, +1 expansion tank stainless steel heat exchangers, 2L brake fluid reservoir front struts glass, door and vent, rear lighting, front. rear, turn, fog, housings and lenses heating system ducts aftermarket steering wheel x2 with mounting hubs 4 bolt Fuchs with lug bolts 5 bolt Fuchs 6x16 x4 1 pair with RA-1's for 911SC/Carrera 5 bolt Fuchs 7x16 x2 5 bolt Fuchs 6x15 with Hoosier slick 5 bolt Fuchs 6x15 x2 911SC front spoiler '69T 2.0L engine (see 6192376 blog) '70T 2.2L engine 6106641 914-6 oil cooler 914-6 engine sheet metal 914-6 oil tank Patrick oil tank 914-6 oil lines 914-6 throttle linkage kit 914-6 flywheels, clutch disc, pressure plate, throw out bearing cooling fans and alternators 911 engine shrouds; black, orange and red quick 6 engine mount bar 2.2 heads, set 2.2T pistons and cylinders, refurbished/honed carrera chain tensioner kit
1 user(s) viewing
1 guest(s)
0 member(s) 0 anonymous member(s) Unknown Search Engine Search My Blog
