![]() ![]() 999.704.172.50 sealing ring 914:101-10 #24 qty:3 999.107.173.50 sealing ring 914:104-00 #2 qty:1 900.123.011.30 sealing ring A 22 x 27 for 900.136.013.02 union A 16 qty:1 oil bypass modification: http://forums.pelicanparts.com/911-engine-...ild-videos.html 911.107.008.01 oil pump 76-> PET 104-00 (911 1977) #(1) 911-911E/ springs, guide, plugs case, cam housings and cam towers taken to Allied Machine shop for cleaning $100 total engine management system http://www.clewett.com/index.php?main_page=index&cPath=2 youtube video SEXY! https://www.youtube.com/watch?v=FT-f9ov5ypQ&NR=1 11/13/14 dropped off case and 11 through bolts/washers/nuts 12/08/14 stopped by to see progress, none to date, still waiting 01/13/15 project on hold due to CABG surgery 02/20/15 stopped by to check on status, no progress, still waiting 03/24/15 Mulligan CABG 04/17/15 6106641 type 911/07 arrives 05/18/15 stopped by to check on case. It's being worked on. 06/07/15 thanks to Gary, Chris, Rod, mark, mark, rob, Jon, Pete, Porsche friends, music friends. Church friends. My family I love you barb Kate jame Kim precious grandchildren. 07/14/15 Not dead yet, ignore tone of 06/07/15 entry. Removed frequency valve block-off, reinstalled frequency valve "Four separate oil lines are required to connect the oil tank to the engine." http://www.pelicanparts.com/914/914-6_cons..._info_guide.htm http://www.914world.com/bbs2/index.php?showtopic=247015 2.2E p's & c's http://lnengineering.com/index.php/product...piston-set.html shift linkage solution, CV's http://www.tangerineracing.com/transmission.htm machine shop for crankshaft and rods https://www.facebook.com/pages/Burtonsville...154349891267211 Mar 10, 2015: 6106641 2.2T not including carbs, distributor, coil, wires. Includes fan and housing, engine shroud, flywheel clutch pressure plate assembly ![]() ![]() ![]() ![]() https://www.youtube.com/watch?v=l5GVA-RU4zQ engine startup at Tangerine Racing ![]() ![]() chain tensioner tech article: http://www.pelicanparts.com/techarticles/9...tensioners2.htm
0 user(s) viewing
0 guest(s)
0 member(s) 0 anonymous member(s) Search My Blog
