WTB, Misc parts |
WTB, Misc parts |
ILM914 |
Oct 6 2009, 05:17 PM
Member Group: Members Posts: 98 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hello: Any help is appreciated I'm still looking for the following parts:
Battery Tray and support Bent fuel injector lines Rubber (4) Stud for Thermostat Bracket ( into case) Rear Shifter boot (where rod goes into plastic housing) E-Brake retaining clip/s (2) E-brake cable rubber boots/seals Thank you, Joe |
detoxcowboy |
Oct 6 2009, 09:21 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Hello: Any help is appreciated I'm still looking for the following parts: Battery Tray and support Bent fuel injector lines Rubber (4) Stud for Thermostat Bracket ( into case) Rear Shifter boot (where rod goes into plastic housing) E-Brake retaining clip/s (2) E-brake cable rubber boots/seals Thank you, Joe in the order you listed you can get them at pelican parts auto atlanta you local hardware store (even of same hardness 4.8 i think but maybe 8.8) pelican parts (check under 911,912 etc..) pelican parts the boots i have never seen except with cable purchases they are already on the cables but you can try auto atlanta.. |
bdstone914 |
Oct 6 2009, 10:22 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hello: Any help is appreciated I'm still looking for the following parts: Battery Tray and support Bent fuel injector lines Rubber (4) Stud for Thermostat Bracket ( into case) Rear Shifter boot (where rod goes into plastic housing) E-Brake retaining clip/s (2) E-brake cable rubber boots/seals Thank you, Joe in the order you listed you can get them at pelican parts auto atlanta you local hardware store (even of same hardness 4.8 i think but maybe 8.8) pelican parts (check under 911,912 etc..) pelican parts the boots i have never seen except with cable purchases they are already on the cables but you can try auto atlanta.. The e brake cable boots are probably available from Porsche. I have a NOS one but not interested in selling it. Bruce |
Lo-Fi Version | Time is now: 27th September 2024 - 10:45 AM |
