914 Front Brake Upgrade, 944 Turbo Calipers |
MikeSpraggi |
Nov 14 2009, 03:29 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
Is anyone out there running 944 Turbo front brake calipers on their 914? I have struts with 3.5" spacing, but what else do I need to make these work up front ... rotors, proportioning valve, etc.? Rear calipers will be SC.
Thanks |
zig-n-zag |
Nov 14 2009, 05:11 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
Go to www.vehiclecraft.com. They have kits/adapters for 944T brakes to 911 struts.
ClayPerrine |
Nov 15 2009, 04:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve.
Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. |
MikeSpraggi |
Nov 15 2009, 09:09 AM
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve. Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. Even with the 911 3.5" spaced struts I will still need to do some offset drilling of the caliper mounting holes? |
rfuerst911sc |
Nov 15 2009, 09:12 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve. Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. Even with the 911 3.5" spaced struts I will still need to do some offset drilling of the caliper mounting holes? Yes I think the spacing is 3.750 or close to that. The right way to do this is have the holes welded up and then machine the correct spacing. The backyard way is to elongate the holes to fit. |
Vysoc |
Nov 15 2009, 09:28 AM
Vysoc Group: Members Posts: 588 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Correct, the spacing on the 944T Caliper is 3.75", Vehiclecraft offers a product designed specifically for this application, it is not cheap.
Vysoc |
Gary |
Nov 15 2009, 12:33 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve. Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. I'm running this setup on mine. Rich Johnson supplied the modified struts as part of a 5-lug upgrade "kit": koni red strut inserts, calipers, carrera discs, drilled rears, etc. Even loaned me the tool to change the rear bearings. Stops great. Given the wide availability of boxster parts and lack of 944T/C2 caliper rebuild kits, I'd probably go this route today. |
iamchappy |
Nov 15 2009, 04:07 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I run 944t brakes on all 4, backyard method machining the holes on the fronts, i have never heard of any failure when done this way on race cars. 23mm master cylinder.
Steve |
Nov 15 2009, 09:47 PM
914 Guru Group: Members Posts: 5,685 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I don't know how much it matters but you will want to swap the bleaders and oil line bar on the calipers. The arrow on the caliper should match the tire rotation. You want the small piston on the top and the big one on the bottom. I had to do the same thing on my Boxster calipers because the 944 turbo and boxster put the front calipers on the back of the brake disk versus the front.
Lo-Fi Version | Time is now: 27th September 2024 - 06:19 AM |
