easy electrical question, attaching a cd changer |
7391420 |
Mar 20 2004, 10:36 AM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
I'm trying to attach a cd changer (w-fm modulator) to the stock radio on my 73. The two wires I need to attach are,
1. wire from the changer to the ignition terminal, so that it gets power when the car is turned on 2. wire to a terminal that always has power going to it... where do I find these terminals? what would you all recommend? I am thinking that I shouldn't just splice into the existing electrial connection to the radio, but I haven't done this kind of thing before so I'm not really sure where to attach these wires! Help! |
TheCabinetmaker |
Mar 20 2004, 10:43 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Attach the wire that needs to be on the ignition circuit to the back of the fuse block where the radio hooks up. The Always on wire, can attach to a fuse that is always on. If you have a new style stereo (one with a digital clock), it already has those connections that you can splice into.
TheCabinetmaker |
Mar 20 2004, 10:45 AM
BTW, always turn the changer off before killing the ignition.
7391420 |
Mar 20 2004, 11:24 AM
Isn't the wire that attaches to the radio always on? I can turn the radio on without having a key in the ignition?
Malmz |
Mar 20 2004, 11:35 AM
CSOBOSC founding member Group: Benefactors Posts: 489 Joined: 22-April 03 From: So. Cal Member No.: 602 |
QUOTE(7391420 @ Mar 20 2004, 09:24 AM) Isn't the wire that attaches to the radio always on? I can turn the radio on without having a key in the ignition? It shouldn't be. Somebody probably swapped it so they could listen to the radio with the car off since a 914 doesn't have an ACC position. sm |
TheCabinetmaker |
Mar 20 2004, 11:37 AM
Malmz is correct. The radio should connect to a switched fuse.
Malmz, your avatar sucks as bad as hung does (IMG:style_emoticons/default/laugh.gif) |
7391420 |
Mar 20 2004, 11:54 AM
ok,
I just pulled off the fuse pannel, so given that the yellow wire coming off the radio is plugged into a socket that allows it to run all the time, should I use this one for the "always on" and if so, where on the fuse pannel should I connect the other wire ? -Adam |
Malmz |
Mar 20 2004, 11:56 AM
QUOTE(7391420 @ Mar 20 2004, 09:54 AM) ok, I just pulled off the fuse pannel, so given that the yellow wire coming off the radio is plugged into a socket that allows it to run all the time, should I use this one for the "always on" and if so, where on the fuse pannel should I connect the other wire ? -Adam Sure. Make sure the changer has a good clean ground somewhere too. sm |
Malmz |
Mar 20 2004, 11:58 AM
QUOTE(vsg914 @ Mar 20 2004, 09:37 AM) Malmz, your avatar sucks as bad as hung does (IMG:style_emoticons/default/laugh.gif) What!?! no love for the Hung? I'm impartial to him right now since one of my clients has his merchandising rights and I'm building a website... (IMG:style_emoticons/default/wink.gif) sm |
7391420 |
Mar 20 2004, 12:22 PM
Thanks for the help,
I will hook up the always on wire to the terminal where the radio is connected, and then find another terminal for the other one, I am assuming that I can just pick an empty terminal and attach to it? |
TheCabinetmaker |
Mar 20 2004, 12:28 PM
Adam,Yep, that should do it. make sure the key is off when plugging in the wire.
Malmz. ok, but don't expect to get any of my money! (IMG:style_emoticons/default/barf.gif) |
7391420 |
Mar 20 2004, 04:28 PM
Once again the club comes through!
I finished the install, tidy'ed up all the wires, and fireed her up and it works really well. FYI-I used a pioneer 6 disk changer with an fm modulator, with remote. I have the origional Blaupunkt, I think it is the Frankfurt, and new pioneer speakers. The sound is surprisingly good, not new car good but considering a 30yr old radio, it works very well. If anyone is interested in pics I'll post them |
McMark |
Mar 20 2004, 05:47 PM
Who isn't interested in pics.
It's a GIVEN!!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) And finally.... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Malmz |
Mar 20 2004, 07:34 PM
QUOTE(markd@mac.com @ Mar 20 2004, 03:47 PM) Who isn't interested in pics. It's a GIVEN!!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) And finally.... (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) You asked for it! (IMG:style_emoticons/default/lol3.gif) (IMG:style_emoticons/default/lol3.gif) (IMG:style_emoticons/default/lol3.gif) Oh, you meant the stereo....................... Attached image(s) |
7391420 |
Mar 21 2004, 09:03 AM
Here's the Pics
Thanks again! -Adam Attached image(s) |
7391420 |
Mar 21 2004, 09:04 AM
oops,
I cant figure out how to post multiple...here's another try, Attached image(s) |
7391420 |
one more
Attached image(s) |
7391420 |
Mar 21 2004, 09:05 AM
front trunk mount
Attached image(s) |
7391420 |
Mar 21 2004, 09:07 AM
wires tidy'd up
Attached image(s) |
TheCabinetmaker |
Mar 21 2004, 09:17 AM
Your welcome Adam. I mounted mine on the bulkhead. Still need to tidy up the rats nest of wires. Hmmm, maybe a good project for today. No 914's in the shop this weekend cept mine. (IMG:style_emoticons/default/boldblue.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:55 AM |
