Front camber/caster adjustment, Expansion tank in the way |
Phoenix-MN |
Feb 10 2010, 11:52 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
So, what tool do you guys use to loosen/tighten the allen head bolt thats circled (in the borrowed picture). The expansion tank is in the way. A realy long allen wrench with a short leg?
Thanks Paul |
TheCabinetmaker |
Feb 10 2010, 11:54 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Remove expansion tank? |
underthetire |
Feb 10 2010, 11:55 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
So, what tool do you guys use to loosen/tighten the allen head bolt thats circled (in the borrowed picture). The expansion tank is in the way. A realy long allen wrench with a short leg? Thanks Paul I'm sure i'll get (IMG:style_emoticons/default/hanged.gif) but i use a small pipe wrench. |
topatrout914 |
Feb 10 2010, 11:57 AM
Trout Group: Members Posts: 64 Joined: 13-October 06 From: Thomasville, NC Member No.: 7,034 Region Association: South East States |
Take the exp. tank off. Two small bolts on the back side IIRC.
r_towle |
Feb 10 2010, 12:01 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
remove the tank...its a five minute job.
Whatever you do, dont use a pipe wrence or vice grips. (IMG:style_emoticons/default/poke.gif) Rich |
Phoenix-MN |
Feb 10 2010, 12:05 PM
remove the tank...its a five minute job. Whatever you do, dont use a pipe wrence or vice grips. (IMG:style_emoticons/default/poke.gif) Rich I guess thats the route I'll take. It's just a pisser to have to take things apart when you've just put it all together (IMG:style_emoticons/default/mad.gif) Thanks |
yeahmag |
Feb 10 2010, 12:09 PM
Advanced Member Group: Members Posts: 2,435 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Those bolts are a real pain in the butt for being two 10mm bolts... I hate putting that thing on and off. I've been tempted to work out *any* other solution.
Phoenix-MN |
Feb 10 2010, 01:45 PM
Those bolts are a real pain in the butt for being two 10mm bolts... I hate putting that thing on and off. I've been tempted to work out *any* other solution. Well, an extreme solution would be to drill a 3/4" hole in the right palce on the expansion tank and weld in a tube to pass a long allen wrench through... ala a 911 heat exchanger (IMG:style_emoticons/default/wacko.gif) |
andys |
Feb 10 2010, 02:10 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
I'll have to look at my car, but I don't recall this being a problem with the plastic expansion tank ('75).
Andys |
r_towle |
Feb 10 2010, 02:28 PM
10mm socket, long extension...5 minute job
Once you set your alignment you are done...no need to play with it unless you are swapping tires for an autox. Rich |
Lo-Fi Version | Time is now: 27th September 2024 - 08:29 AM |
