Steering wheel & horn wire, clip broken off |
EJP914 |
Mar 9 2010, 09:59 PM
Member Group: Members Posts: 262 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Does anyone have a fix for repairing the tab or clip on the backside of the horn pad in the center of the steering wheel? I found the wire that comes thru the column laying in the center of the wheel hub with the clip stuck in it - broken off from where it attaches. Would drilling a hole in the aluminum plate and putting a bolt and nut on it to hold the wire work? Car is a '74
Maybe someone has a better idea? Thanks for the advice. |
McMark |
Mar 9 2010, 10:04 PM
You can get these types of connectors and rivet it to the plate (it's steel). McMaster-Carr has 'em (thanks for the pic) but only in packs of 100. Try RadioShack.
Attached image(s) |
cwpeden |
Mar 9 2010, 10:16 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I installed a digital horn.
You can use any digit you like. Helps keep me from givin people the finger! Seriously, I've got three horn buttons. Two with bust spades and one without. Its the rubber thats the issue. With AX suspension set to med-hard all the time, I drive around honking my horn at every bump in the road. Try Radioshack or whatever electronics part place you have nearby. They have them in smaller quantities, not always exactly what you need but usualy close. Conrad |
markb |
Mar 10 2010, 12:06 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
You can get these types of connectors and rivet it to the plate (it's steel). McMaster-Carr has 'em (thanks for the pic) but only in packs of 100. Try RadioShack. (IMG:style_emoticons/default/agree.gif) |
914Sixer |
Mar 10 2010, 06:28 AM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You can just get a new steering wheel horn assembly. It is the same as a stock VW Beetle. Look them up on the internet. They run about $30
Lo-Fi Version | Time is now: 27th September 2024 - 05:38 PM |
