pedal cluster mod, to stop the wobble |
rwilner |
May 6 2010, 07:27 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
When I press my brake pedal, the little plate that holds the clutch/brake stop moves a little bit. It's pretty annoying.
I dug into it and there is a nut that attaches that plate to the pedal base. I snugged it up and no improvement. I think if I install a bolt on the front of that plate through the base, the issue will go away. But, I wanted to get input from the group before I bust out the drill. the pedal cluster appears to be in good repair otherwise, bushings are brass and the parts don't have any rust to speak of. does anyone else experience this? how did you fix it? (or do you just live with it?) Pics: |
Eric_Shea |
May 12 2010, 05:59 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Is there a lock washer under that thin 13mm nut?
I would have suspected the bushing behind that plate but, if they're "all" bronze then that may not be it. Personally, I'd look for the real problem before drilling holes in my pedal assembly. With good bushings and a lock washer under the nut you should be firm... something else is wrong. Clutch shaft may be worn. (IMG:style_emoticons/default/confused24.gif) |
rwilner |
May 12 2010, 06:10 PM
Is there a lock washer under that thin 13mm nut? I would have suspected the bushing behind that plate but, if they're "all" bronze then that may not be it. Personally, I'd look for the real problem before drilling holes in my pedal assembly. With good bushings and a lock washer under the nut you should be firm... something else is wrong. Clutch shaft may be worn. (IMG:style_emoticons/default/confused24.gif) Eric i don't see a lock washer -- I'll install one. How do you get on that nut while it's in the car? Do you use a wobble? |
Lo-Fi Version | Time is now: 27th September 2024 - 08:32 AM |
