External or Internal Transmission Problem?, Which one |
damnfiknow |
Jul 7 2010, 03:22 PM
Member Group: Members Posts: 77 Joined: 25-October 09 From: Texas Member No.: 10,980 Region Association: None |
Was having 1st and 2nd gear problems (full stop for shift to 1st and almost impossible 2nd), so pulled the trans out of my donor car (how duz one have a 914 without at least one donor?) and inserted in the active car. Replaced all bushings from firewall back. Now a "non crisp" selection to 2nd (feels mushy) going in (no xxx thoughts please) and next to impossible to get 4th. Reverse, 1st, 3rd and 5th ok. Maybe help with adjustment at the shift stick (hope, hope hope) or do I need rebuild/replacement?
Cupomeat |
Jul 7 2010, 03:31 PM
missing my NY 914 in VA Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Well, were you able to isolate that you did not have a dragging clutch for the initial transmission, which is what is sounds like was the problem?
Otherwise, it sounds more like linkage alignment than internal transmission given your description. I hope that helps. |
damnfiknow |
Jul 7 2010, 03:47 PM
Well, were you able to isolate that you did not have a dragging clutch for the initial transmission, which is what is sounds like was the problem? Otherwise, it sounds more like linkage alignment than internal transmission given your description. I hope that helps. Thanks for the encouragement. I Replaced the disk and releasebearing plus the piviot bushing. |
RJMII |
Jul 7 2010, 09:21 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Did you check the clutch cable tube inside of the tunnel?
Lo-Fi Version | Time is now: 27th September 2024 - 08:07 AM |
