Next Resto Project, Intake Tubes |
Pat Garvey |
Jul 19 2010, 07:18 PM
While I'm waiting for parts for the gas tank switch, I thought I'd get started on another project that I've been putting off - intake tubes.
When I redid my originals in 1989, I made the mistake of clearcoating them. Man, did they look great for 7-8 years, before then engine heat took over. Still don't look horrible, but you can tell. So, I have two extra sets (eBay). Both are gross! I intended to refurbish both, but the red set has bad clips, so it will go in the trash tomorrow night. The other set - silver-on white-on gray look like the have potential. So, I started citris stripping them tonight. It's 86 degrees in the garage, so the stripping should be enhanced by the heat (unlike me). The red ones are free to anyone so inclined, but you need to let me know by tomorrow night! They are really crude. I must start throwing this stuff out. Pics attached Attached image(s) |
Bleyseng |
Jul 20 2010, 12:56 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
build yourself a soda blaster or a rust removal tank with a spare battery or battery charger. Its amazing how clean it gets stuff! no more stripping crap for me...
windforfun |
Jul 20 2010, 01:30 PM
Senior Member Group: Members Posts: 1,956 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Bad clips? How so?
type47 |
Jul 21 2010, 08:30 AM
I sent mine to the powdercoaters and really like the finish.
Pat Garvey |
Jul 21 2010, 07:11 PM
Pat Garvey |
Jul 21 2010, 07:18 PM
Pat Garvey |
Jul 21 2010, 07:20 PM
Sleepin |
Jul 22 2010, 10:17 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I had mine powdercoated, they look great. I used 65% gloss finish, and I think they still are a little glossy, but not bad. Plus they are easy to clean.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-8357-1279815435.1.jpg) |
tod914 |
Jul 22 2010, 05:14 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Eric, if you take 800 to 1000 grit and wet sand it, you'll get a nice matt finish on them. Just don't use any polishes or compound after sanding. The scotch bright pads work well too for the harder to get areas. That's what I ended up doing with mine. I'm happy with the results. Nice color match btw. What RAL color is it?
Pat Garvey |
Jul 22 2010, 06:43 PM
Eric, if you take 800 to 1000 grit and wet sand it, you'll get a nice matt finish on them. Just don't use any polishes or compound after sanding. The scotch bright pads work well too for the harder to get areas. That's what I ended up doing with mine. I'm happy with the results. Nice color match btw. What RAL color is it? Tod - pics of yours please? Installed is OK too. Pat |
mepstein |
Jul 22 2010, 07:06 PM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Pat - I appreciate what your doing to get your car back in shape. It's one I'd really like to see and I think I live pretty close to you. Even if it isn't looking perfect, you should think about getting it on the road. These cars are so fun and a day like today would be teriffic. Just thinking out loud. Best of luck, Mark
tod914 |
Jul 22 2010, 08:33 PM
I'll try to get some better shots for you Pat. Unfortunetly my Fuji camera tends to oversaturate colors. They appear to be too blue in the pictures. I'll see if I can color correct to make it a more accurate representation.
Pat Garvey |
Jul 28 2010, 06:32 PM
Eric, if you take 800 to 1000 grit and wet sand it, you'll get a nice matt finish on them. Just don't use any polishes or compound after sanding. The scotch bright pads work well too for the harder to get areas. That's what I ended up doing with mine. I'm happy with the results. Nice color match btw. What RAL color is it? Tod, If you don't apply any wax/polish - what keeps them from oxidizing, especially in the heat of the engine compartment? I made the mistake of clearcoating mine when I re-did them 20 years ago. Yep, the paint underneath is fine, but the heat yellowed to clearcoat. Pat Oh, and just to clear this up, the cast pieces ARE supposed to be painted also - right? |
Pat Garvey |
Jul 28 2010, 06:39 PM
Pat - I appreciate what your doing to get your car back in shape. It's one I'd really like to see and I think I live pretty close to you. Even if it isn't looking perfect, you should think about getting it on the road. These cars are so fun and a day like today would be teriffic. Just thinking out loud. Best of luck, Mark ark, Thanks for the reply. Look, I've owned this 914 for 38 years (I was 25 when I bought it new). We've done a bunch of atocrossing with it in the past, and have maintained it to hardcore concors specs (38 "real" trophies), but I'm now 63 and a bit arthritic, so things move way more slowly. In fact, the car will be shipped to Ohio over the winter to have the mechanicals brought back into spec. I just can't physically do it anymore. Oh, it will be made roadworthy. Thankfully, I have no rust issues. To quote Dirty Harry - "man should know his limits". I do, & it's time to find a younger man to help. Pat |
tod914 |
Jul 28 2010, 07:06 PM
Pat I don't think the powder will change over time, like I did mine. The scuffing does lighten it slightly. I'll post a shot of it for you, but keep in mind they are not this blueish in person. I don't have any programs loaded on the computer to color correct it atm.
What I noticed about some of the intake runner photos I have, some of the grey paint will get darker, while others lighter over time. Guess chemicals and heat play a part on how it changes. I'm trying to find a can of the Rustoleum 2000 temp high heat paint. One member tried it, and it looked very good. Much closer than the VHT. Here's a photo of the engine bay with them installed. PS if you would like all the reference photos of the original paint runners, happy to send them out to you. |
Pat Garvey |
Jul 30 2010, 06:32 PM
Pat I don't think the powder will change over time, like I did mine. The scuffing does lighten it slightly. I'll post a shot of it for you, but keep in mind they are not this blueish in person. I don't have any programs loaded on the computer to color correct it atm. What I noticed about some of the intake runner photos I have, some of the grey paint will get darker, while others lighter over time. Guess chemicals and heat play a part on how it changes. I'm trying to find a can of the Rustoleum 2000 temp high heat paint. One member tried it, and it looked very good. Much closer than the VHT. Here's a photo of the engine bay with them installed. PS if you would like all the reference photos of the original paint runners, happy to send them out to you. I would love to see them. May not want to bore the others with them, so feel free to send any/all topg914@netzero.com Thanks |
tod914 |
Jul 31 2010, 09:04 AM
Will do Pat. Just need to organize them abit better.
Pat Garvey |
Jul 31 2010, 07:07 PM
tod914 |
Aug 1 2010, 02:25 PM
Pat bad email address
Hi. This is the qmail-send program at yahoo.com. I'm afraid I wasn't able to deliver your message to the following addresses. This is a permanent error; I've given up. Sorry it didn't work out. <topg914@netzero.com>: Remote host said: 550 topg914@netzero.com is not a valid user |
Sleepin |
Aug 6 2010, 06:54 PM
Eric, if you take 800 to 1000 grit and wet sand it, you'll get a nice matt finish on them. Just don't use any polishes or compound after sanding. The scotch bright pads work well too for the harder to get areas. That's what I ended up doing with mine. I'm happy with the results. Nice color match btw. What RAL color is it? I can't remember which color we chose with those. I believe I took in a paint cap to Ford engine grey and then went one shade darker IIRC. They are really close to pictures I have seen of other manifolds. I am not too concerned with the finish, the gloss makes it easier to keep clean. I think with a matte finish, they would be close to factory original though. |
Lo-Fi Version | Time is now: 27th September 2024 - 10:24 AM |
