heater blower switch |
biker bob |
Nov 6 2010, 03:04 PM
Member Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region |
Where is the switch that turns on the rear heater blower? No power to the blower.
swl |
Nov 6 2010, 03:09 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
red lever behind the shifter
tradisrad |
Nov 7 2010, 10:54 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
the lever is a ground and when in it's full up position it completes the ground for the fan. on some years you need a jumper on the relay board. it is the green wire in this picture (ignore the comment box; picture is from other post) what year is your car?
go a step further and install a bulb in the dash vent controls so you know when the fan is on. use the heater switch as your ground and pull the +12 from the fresh air fan light. I don't know why the factory did not wire this light; the control panel has a place for a factory bulb and the red screen... |
Rav914 |
Nov 8 2010, 08:52 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Cool! I had no idea there were lights there.
tradisrad |
Nov 8 2010, 09:54 AM
Lo-Fi Version | Time is now: 26th September 2024 - 09:46 PM |
