Shifting troubles, How to properly do it |
recko911 |
Feb 17 2011, 10:58 PM
Member Group: Members Posts: 93 Joined: 6-February 06 From: Los Angeles, CA Member No.: 5,535 |
Im having some difficulties with adjusting the shifting. All bushings are new, and motor mounts. Where do you set transmission at the side shift. Can someone describe a good process. Thanks
TROJANMAN |
Feb 17 2011, 11:02 PM
Looks nice in pictures......... Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
If your transmission is good, and you've replaced ALL of the bushings, you just may need to adjust the shifter in the center console. Remove the plate, and I think it takes a 10mm socket?? Isn't everything a 10 or 13? (IMG:style_emoticons/default/biggrin.gif) Loosen it up then shift to a gear and when you find a gear, tighten it back up.
recko911 |
Feb 17 2011, 11:08 PM
If your transmission is good, and you've replaced ALL of the bushings, you just may need to adjust the shifter in the center console. Remove the plate, and I think it takes a 10mm socket?? Isn't everything a 10 or 13? (IMG:style_emoticons/default/biggrin.gif) Loosen it up then shift to a gear and when you find a gear, tighten it back up. I'm having trouble adjusting at the center console. How to find proper location while 13mm screw is loose. |
stugray |
Feb 18 2011, 09:08 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
It is a PITA.
To line up the shifter to the proper gear (side to side) you have to move a spline or two one direction or the other. That is just trial and error. Once you find the "gates" to the gears, then you adjust how far in or out the two pieces are relative to each other. This adjusts how far forward/back the lever needs to move to fully engage the gears. Stu |
detoxcowboy |
Feb 18 2011, 10:18 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
http://www.914world.com/bbs2/index.php?act...t&id=218669
It is in this link.. how to adjust the shift lever console .. starting page 27 |
Dr Evil |
Feb 18 2011, 10:40 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Who ever wrote that is a fricken GENIUS! (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 02:07 PM |
