2.7 guys |
2.7 guys |
RiqueMar |
Feb 28 2011, 05:38 PM
Enrique Allen Mar Group: Members Posts: 2,176 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
What do you guys like/not like for clutch/Flywheel? Going with a 2.7 the 901 Sideshift, and about to put down some $$$.
Likes? Dislikes? Horror stories? |
SLITS |
Feb 28 2011, 05:41 PM
I use a stock 2.0L /4 setup with the early 901 flywheel. No problems on 3 engines.
Cap'n Krusty |
Feb 28 2011, 06:24 PM
Slits beat me to it. It's a bolton. You'll need the flywheel, the shim, the pilot bearing, and a set of new bolts
The Cap'n |
john rogers |
Feb 28 2011, 06:29 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
What are you planning to do with the car? If it is a street and occasional auto-x driver then you are okay with stock internals. You might need a limited slip of some sort since a 2.7 will just burn a single drive wheel right off. If you are also driving less and auto-x/DE/time trial more then a re-gear so the top 3 gears are M-S-X which will put 2nd thru 5th closer together and make the car a lot more fun to drive and faster.
Scott S |
Jun 3 2011, 05:20 PM
Small Member Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Sorry to re-up an old thread... getting ready to place an order...
Capn, Ron - do you stay with the 4 spring clutch disc or up it to the 911 6 spring disc? Thanks! Scott S |
Dr Evil |
Jun 3 2011, 06:04 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Great bolt on engine (IMG:style_emoticons/default/smile.gif)
Cap'n Krusty |
Jun 3 2011, 06:17 PM
Sorry to re-up an old thread... getting ready to place an order... Capn, Ron - do you stay with the 4 spring clutch disc or up it to the 911 6 spring disc? Thanks! Scott S I've never used the 4 spring disc. Used to be the 6 spring disc was cheaper, now it's 3 times as much. I haven't done a 914 clutch in about 10 years, BTW, so that caught me by surprise. The currently available 914 disc has 6 springs, and I suspect it's a bus disc, made in Brazil by Sachs. Your choice |
SLITS |
Jun 3 2011, 07:48 PM
They are all 6 spring now .... supposedly smoother on takeup. Both Sachs kits I bought were six spring. I forget the kit number, but for shits and giggles ask for the early 911 2.0L kit. I can look tomorrow.
None of them are cheap .... they're made for Porsche |
BKLA |
Jun 3 2011, 09:23 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
I went with the lightened Patrick Motorsport flywheel with the centerforce P.Plate and clutch. (RS spec 2.7) It is a track day car (and AX once in a blue moon).
No problems so far, and I like how quick the 6 spins up. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:17 AM |
