Having trouble finding a part number, engine case studs |
Scott S |
Apr 20 2011, 02:21 PM
Small Member Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
My 2.7 is missing the mounting studs for the transmission. Pelican does not have them and advised me to call parts haven. Parts haven said they should be able to pull some old ones out of an old case, but I should try the dealer for new ones. The part numbers they gave me are: - 999 062 138 02 - 999 062 051 02 When I look these up in PET, they are not the parts I am looking for. Does anyone know the actual part number for the studs that are installed in engine the case that are used to mount the tranny to the case? Thanks! Scott S |
Rex-n-effect |
Apr 20 2011, 02:33 PM
Newbie Group: Members Posts: 44 Joined: 4-February 11 From: Missoula, MT Member No.: 12,659 Region Association: None |
Should be part # 999 061 034 02. 10 x67mm. That would be item # 6 on Ill. # 101-05.
Pretty sure that is what you want.... |
Cap'n Krusty |
Apr 20 2011, 02:47 PM
Hi All - My 2.7 is missing the mounting studs for the transmission. Pelican does not have them and advised me to call parts haven. Parts haven said they should be able to pull some old ones out of an old case, but I should try the dealer for new ones. The part numbers they gave me are: - 999 062 138 02 - 999 062 051 02 When I look these up in PET, they are not the parts I am looking for. Does anyone know the actual part number for the studs that are installed in engine the case that are used to mount the tranny to the case? Thanks! Scott S There are 2 bottom studs, 999 061 034 02 (M10x67) and one top bolt, 999 062 165 02 (M10x75). The starter side top stud is 999 062 110 02 (M10x115) That stud takes a cylinder head nut. There are 2 10mm wavy washers on the bottom, and 10mm x 15mm wrench size nuts. There's one of those on the top, too, but there you use a flat washer and a serrated locking washer (both sides on the top). I probably have that stuff if you really need it. The Cap'n |
Lo-Fi Version | Time is now: 27th September 2024 - 12:43 PM |
