FS 76 Porsche 914, The Axis powers... $4500 OBO |
RJMII |
May 8 2011, 06:45 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
My build thread is in my signature. Body: hell hole is fine. it needs vacuumed out and coated. jack points are fine. front trunk has a radiator in it and full of holes. bumpers were back dated, and the front one has a hole in it with an aluminum grill for air flow d-side front of the car has been hit, and has been repaired by someone that didn't know what they were doing. it looks okay with the trunk closed. rear trunk has a BIG hole in it from where I took the sawzall to it to get the engine to fit. suspension: front is 911 SC, has 19mm m/c to match the bigger brakes. rear has yellow konis and five lug hubs done by PMB interior was redone, it's slightly apart right now engine: (pulled, no longer in car) current engine has a knock, and a turbo that needs a rebuild. it's a mitsubishi 6g75 with a BIG 16G turbo. engine management is Megasquirt 2 using Ford EDIS 6 for spark distribution Replacement engine (comes with) EDIT: partially installed now! Twin turbo engine from a 95 mitsubishi 3000GT VR4 it should bolt in right where the other engine is sitting. It will require a little bit of different plumbin to switch from single turbo v6 to twin turbo V6. |
snowman |
May 11 2011, 03:08 PM
I'm new here ... Group: Members Posts: 0 Joined: 26-April 11 From: Montréal Qc Canada Member No.: 12,984 Region Association: None |
need pictures |
RJMII |
May 11 2011, 03:26 PM
I'll add more pictures when i get out of the hospital again.
Attached image(s) |
chuckc |
May 13 2011, 09:58 AM
Member Group: Members Posts: 196 Joined: 30-August 10 From: Astoria NY Member No.: 12,123 Region Association: North East States |
I'll add more pictures when i get out of the hospital again. If I lived closer I would be seriously tempted to sell mine and buy yours. On a side note it's good to see someone that loves their wife like that! (IMG:style_emoticons/default/beerchug.gif) good luck with the sell. chuck |
AgPete139 |
Sep 27 2011, 02:47 PM
AgPete139 Group: Members Posts: 91 Joined: 12-February 08 From: Houston, TX Member No.: 8,701 Region Association: South East States |
I liked this build, too.
Pete |
RJMII |
May 27 2012, 12:50 PM
chuckc |
Jul 12 2012, 08:37 AM
did you get her running? this is the perfect rat sleeper.
Lo-Fi Version | Time is now: 27th September 2024 - 12:58 PM |
