Latest Progress Pics, Hydraulic Clutch Conv. |
RON S. |
Jun 2 2004, 04:51 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I've Been working my project for quite some time now,and this summer the 3.6l & 915 trans are finally just about ready for the install.
I have always wanted to have a hydraulic clutch setup when I get it together,so When I was up at the Hershey swap meet,I came across a 964 pedal cluster with a integrated hyd.clutch that when I looked at it I thought that I might could just make it work. It was actually easier than expected. Ron Attached image(s) |
RON S. |
Jun 2 2004, 04:54 AM
The entire master cylinder is mounted in a added on frame to the 964 pedal cluster.
Drill out a few spot welds,and it pops right off. It is even shaped to weld on the end of the 914 pedal cluster bracket. Attached image(s) |
RON S. |
Jun 2 2004, 04:57 AM
The only real work done after that was to cut down the length of the large sleeve that holds the brake pedal by about 3/8",and make a new clutch rod.
the clutch rod is 14mm in dia.I bought a pc. of 14mm drill rod from McMaster-Carr for about $8.00. Ron Attached image(s) |
RON S. |
Jun 2 2004, 04:59 AM
I had to re-locate the accelerator linkage,so I used the pivot hole on the added on clutch since it was hollow to begin with.
Attached image(s) |
RON S. |
Jun 2 2004, 05:03 AM
The install in the car was a snap,it has about a 1/2"clearance from the firewall.I did a notch in the trans tunnel,and added 1 stud for the extra mount hole.
It is a 5 minute job to install or remove the entire unit once the brake master cyl. nuts are removed. I used 5/16"brake line out the back for the line. Attached image(s) |
RON S. |
Jun 2 2004, 05:04 AM
Nother interior shot.
Attached image(s) |
RON S. |
Jun 2 2004, 05:06 AM
The reservoir is a Ford Ranger unit I took from a junkyard.It was free.
Attached image(s) |
RON S. |
Jun 2 2004, 05:09 AM
the pedal board I saved for last.The original no longer can be used.So I've programmed my own version with a little twist.
Right now,It's cut from 20ga. steel to check for fit,but when I finalize the design I'm gonna buy 16ga.grade 2 Titanium. Ron Attached image(s) |
sechszylinder |
Jun 2 2004, 05:30 AM
Member Group: Members Posts: 256 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
hi ron,
that's a very nice setup !!! (IMG:style_emoticons/default/smilie_pokal.gif) what kind of slave cylinder do you intend to use ? bye ... benno |
RON S. |
Jun 2 2004, 09:02 AM
Benno,
Wilwood makes a nice pull type slave cylinder. I've seen it used mostly on the dirt track cars. It's less than $60.00 from any race shop so that's what I'm gonna used when the engine & trans are installed. Ron |
airsix |
Jun 2 2004, 10:36 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Ron, that looks great! I really like that approach. You will love it. I did a hydraulic conversion too, but mounted the MC next to the brake MC. If I did another one I'd do it your way for sure!
-Ben M. |
thesey914 |
Jun 2 2004, 10:44 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
(IMG:style_emoticons/default/cool.gif) Awesome (IMG:style_emoticons/default/cool.gif)
Has this been done before or are we witnessing a pioneering moment? |
Lo-Fi Version | Time is now: 27th September 2024 - 10:59 AM |
