Help mounting Clutch/pressure plate |
Bill Meyer |
Sep 29 2011, 03:15 PM
Newbie Group: Members Posts: 44 Joined: 11-October 07 From: Prairie Village, KS Member No.: 8,210 |
I'm bolting down this pressure plate here and something doesn't seem right. As you can see the bolt face goes into the recess on the flywheel. It doesn't hit, but your socket starts slipping since it starts hitting the flywheel. I suppose I can tighten it down carefully with a wrench, but I don't remember this issue when taking it off the old motor.
Confused??... Attached image(s) |
underthetire |
Sep 29 2011, 03:22 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Yep, been there. Get your flywheel machined recently?
proto31 |
Sep 29 2011, 03:25 PM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
Use allen bolts, make sure that they are 10.9 hardened...
Bill Meyer |
Sep 29 2011, 03:44 PM
As a matter of fact it was machined, that explains it, duh... Good idea on the allen bolts.
Thanks guys!! (IMG:style_emoticons/default/beerchug.gif) Use allen bolts, make sure that they are 10.9 hardened... |
Mike D. |
Sep 29 2011, 04:32 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,446 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I have a hardened 13mm for impact wrench that "machined" down around the edge just for this purpose.
76-914 |
Sep 29 2011, 04:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have a hardened 13mm for impact wrench that "machined" down around the edge just for this purpose. (IMG:style_emoticons/default/agree.gif) What he said. Except my machining was hillbilly; done on a grinder:beer2: |
Mike D. |
Sep 29 2011, 04:43 PM
I have a hardened 13mm for impact wrench that "machined" down around the edge just for this purpose. (IMG:style_emoticons/default/agree.gif) What he said. Except my machining was hillbilly; done on a grinder (IMG:style_emoticons/default/beerchug.gif) Mine too, thats why "machined" is in quotes. (IMG:style_emoticons/default/beerchug.gif) |
Cap'n Krusty |
Sep 29 2011, 05:12 PM
If it's that deep, I certainly wouldn't use it. You can't shim the release bearing ball out far enough to make the arm move properly, not to mention clutch disc hub to flywheel bolt clearance.
The Cap'n |
Lo-Fi Version | Time is now: 27th September 2024 - 10:57 AM |
