shift rod, shift rod |
partwerks |
Dec 12 2011, 02:35 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I was wondering if it is possible to use the stock shift rod with the Subie EJ20 engine?
Just eyeballing it, it appears that three things may be touch and go as far as in the road? 1. Tin on header-can it be removed 2. Drivers side of oil pan-be trimmed 3. Tubing on engine cradle I was thinking on the places where it is a close encounter if a person could splice in a piece of rod with a smaller diameter that would give a bit more clearance if needed, like a reducer? On the engine cradle tube in the rear, I was wondering if it is in the road if a person could roll a piece of tubing like a 1/2 moon and splice it in the area where the shift rod would come through at for clearance if needed, like an arch. It appears as though it would just clear the drivers side engine mount? I don't recall if the stock shift rod is straight or has a curvature to it? |
RonnieJ |
Dec 12 2011, 04:48 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
Bump
Dr Evil |
Dec 12 2011, 08:30 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Stock has a curve in it.
Jeffs9146 |
Dec 13 2011, 12:03 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
You can custom weld just about anything to fit!
It was much easier than I thought it would be for my 3.0L conversion! This one works the same as a strait one as long as you get it set right before welding it! The most criticle is the alignment of the front and end as well as the allen screw location. It may not be sexy but it works the same as the strait one! (IMG:style_emoticons/default/KMA.gif) Attached thumbnail(s) |
underthetire |
Dec 13 2011, 12:04 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
(IMG:style_emoticons/default/barf.gif)
Will you please crop that picture. Those toes are nasty! |
Jeffs9146 |
Dec 13 2011, 01:18 PM
(IMG:style_emoticons/default/hissyfit.gif) I smashed my toe that morning!! (IMG:style_emoticons/default/wacko.gif) Edited just for you Jeff! |
Lo-Fi Version | Time is now: 27th September 2024 - 10:02 AM |
