Clutch retaining bolts |
jmargush |
Jan 7 2012, 02:34 PM
Member Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Is there a trick to getting the clutch retaining bolts out? they sit right against the ring gear on the flywheel preventing a socket from sliding on. and I can seem to get a good grip with an open end.
nathansnathan |
Jan 7 2012, 02:44 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I just experienced this in the engine of my parts car. Someone used the wrong bolts and the heads were super close to the edge of the flywheel. There was no 'good way' but I managed with a wrench and even a 1/4" ratchet.
The right bolts are supposed to be smaller wrench size with a serrated flange. |
reharvey |
Jan 7 2012, 02:56 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Is there a trick to getting the clutch retaining bolts out? they sit right against the ring gear on the flywheel preventing a socket from sliding on. and I can seem to get a good grip with an open end. You need a thin wall socket. I make my own by grinding down the outside until it fits over the bolt. Yeah--that's low tech but it works for me. Ray (IMG:style_emoticons/default/biggrin.gif) |
jmargush |
Jan 7 2012, 03:48 PM
I got them out but it wasn't pretty. I compared them to my 1.8 engine that still has the clutch on it and those bolts sit higher that the ring gear almost like the pressure plate on the 2.0 I am tearing down is thinner or the flywheels are different and the 2.0 has a deeper recess inside the flywheel.
rjames |
Jan 7 2012, 05:13 PM
I'm made of metal Group: Members Posts: 4,111 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Hmm, I was able to get a craftsman socket on mine when I replaced the clutch & flywheel on my 75 2.0 recently. (IMG:style_emoticons/default/confused24.gif)
A&PGirl |
Jan 9 2012, 05:17 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
The 1.7/1.8 Clutches use a shorter length bolt than the 2.0.
The -6 Clutches use the same length bolt as the 1.7/1.8. They all should have washers underneath the head. The -6 and -4's list the same p/n for the clutch & pressure plate. |
SirAndy |
Jan 9 2012, 05:48 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You need a thin wall socket. I make my own by grinding down the outside until it fits over the bolt. Yeah--that's low tech but it works for me. Ray (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) Same here ... (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:48 AM |
