where doo the parts go, D-Jetronic parts location |
Mr.JAJA |
Jan 20 2012, 09:28 AM
Newbie Group: Members Posts: 1 Joined: 23-December 11 From: Poway CA Member No.: 13,927 Region Association: None |
Hello and good morning here.
I am new on this Forum and building a 74 914-4 2.0 liter . With having most of the part, I cant find the mounting points for the manifold pressure sensor and the ECU. Dos someone has picture from the location? I tried to match existing holes with the brackets, but no luck. (IMG:style_emoticons/default/confused24.gif) Thank you Mr.JAJA (IMG:style_emoticons/default/newhere.gif) |
DRPHIL914 |
Jan 20 2012, 09:34 AM
Dr. Phil Group: Members Posts: 5,808 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have a 75 d-jet, should be same. the ECU should have a bracket that it mounts to , and the MPS should have a black braket, triangle shape that attaches to the side wall just up from the fuel rail on passanger side, Post a picture of these areas in your car, thismight help us too. welcome to world phil |
76-914 |
Jan 20 2012, 09:56 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) I will post a pic this evening if someone hasn't by then. In the meantime you can post some pic's of your project.
DRPHIL914 |
Jan 20 2012, 10:04 AM
Here is a picture of mine -I its usually mounted the opposite direction, but fit better this way when I put the new harness in.
Attached thumbnail(s) |
rick 918-S |
Jan 20 2012, 10:18 AM
Hey nice rack! -Celette Group: Members Posts: 20,680 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/welcome.png) Check the last post in this thread. I have some very clear photos of the ECU and MAPS.
http://www.914world.com/bbs2/index.php?sho...57169&st=80 This is Sandy's Ravenna car. Also check other posts in the originality forum. |
Dave_Darling |
Jan 20 2012, 12:11 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The ECU bracket bolts to the front of the battery tray.
If air conditioning was installed (at the dealer), they usually moved the ECU up onto the firewall with some L-shaped brackets. --DD |
Lo-Fi Version | Time is now: 27th September 2024 - 01:03 PM |
