Removing dash vent controls., Help |
matthepcat |
Feb 21 2012, 10:54 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I can't seem to remove the dash vent/heater controls.
Is there a trick to getting this out? Thanks for those with the skills to help! Matt |
partwerks |
Feb 21 2012, 11:08 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Are you talking the whole mechanism buried in the dash?
matthepcat |
Feb 21 2012, 11:10 PM
Yes.
Not sure if there is a trick to it, as it does not just push out |
partwerks |
Feb 21 2012, 11:13 PM
Can't say I've looked in there lately, but I would guess it was put in before the dash was put on?
Maybe can take the cables loose and is the mounting bracket bolted on or something so that it can be dropped down through the dash or out the front?? |
kconway |
Feb 21 2012, 11:17 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Disconnect cables under cowl from the trunk, remove mounting bolt, pull out of dash.
Forgot, pull out lights and disconnect spade connectors. |
matthepcat |
Feb 21 2012, 11:26 PM
partwerks |
Feb 21 2012, 11:32 PM
From the sound of things, it would be somewhere around where the fresh air blower motor is I'm thinking??
Mike Bellis |
Feb 21 2012, 11:46 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Bolt is behind control on front firewall. Get to it upside down under your dash.
matthepcat |
Feb 21 2012, 11:58 PM
matthepcat |
Feb 22 2012, 02:59 PM
Finally got it out this morning.
One of the vent cables running into the front trunk is not accessible, so I had to remove it from the dash control panel. I'm really glad that none of this is going back into the car. Thanks guys for your help. Matt |
Lo-Fi Version | Time is now: 27th September 2024 - 01:37 PM |
