what do you carry for spares?, tools, parts, etc. |
mrbubblehead |
Mar 21 2012, 07:23 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
like the title says, what do you guys carry for spares in your daily driving? i try to travel light, but i think i have all the bases covered.
share what you carry. heres my list, 1. a pair of thin coveralls. 2. hazet tool kit (from an old car) 3. the little black bag. 3a. varies 3/8 metric sockets 3b. 3/8 ratchet 3c. little cresent wrench 3d. tie wraps 3e. roll of black tape 3f. little bit of tie wire 4. clutch cable 5. throttle cable 6. oil pressure sensor 7. points, condenser, cap and rotor. (im running a petronix..but you never know) 8. clutch tube repair kit 9. the little plastic chingus on the end of the clutch cable to clutch throw out arm. 10. the little pin chingus for the clutch cable pedal end (it was cheap- what the hell) 11.fan belt 12. little mag light 13. 2 round relays (tested) 14. lug wrench 15. spare tire 16. stock jack (perfect for my lowered car) 17. bike chain (in case i have to chain it to a post or something) 18. dozen fuses (reds and whites) 19. 1 qt of oil things i know i need to add, spare fuel pump (facet) various lamps (maybe a brake, turn signal, running lamp) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332379418.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332379419.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332379419.3.jpg) |
Tom_T |
Mar 21 2012, 07:32 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Nice setup!
I've got a 16 bulb spare set & an 8 or 10 OEM fuse set (IIRC there were 3 or 4 amp sizes) as a back-up - which you mention both, but that is a more complete set Also add a red fuel pump relay & one for headlights & TS (unless they're already new). PP/Automotion/Ecklers, AA, Pelican & maybe others also sell them. Also make sure you have a good transaxle to chassis (under R trunk) ground cable with good connections, so that you won't need the acc. or clutch cables! (IMG:style_emoticons/default/biggrin.gif) |
dlee6204 |
Mar 21 2012, 07:58 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm known for carrying a flat tow setup in my rear trunk... just in case. (IMG:style_emoticons/default/biggrin.gif)
matthepcat |
Mar 21 2012, 08:06 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Fuses
Assorted basic tools CV bolts & matching tool i have a space saver wheel/tire, but only would bring for a theoretical long trip. AAA 100 mile towing card. |
wingnut86 |
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
My add...
1- small flexible/spongy nail file from a local Walgreen's/etc, corrosion tool 2- small collapsible travel toothbrush in case, corrosion tool 3- you should use alcohol to clean corroded contacts and pins, 91% preferred. But, in a pinch or road emergency you can use that alcohol based gel hand sanitizer - make certain it's a small bottle of the generic/no smell/no color/less chance of heat related fire as well 4- a couple of broken off pencils with good erasers. The erasers clean flat copper electrical traces so they sparkle, and it doesn't hurt the contact conductivity either 5- spare wiring harness - just kiddin (IMG:style_emoticons/default/biggrin.gif) |
mrbubblehead |
Mar 21 2012, 10:51 PM
being towed sucks.... the last time i had to have my oval towed, i got into a fight with the tow truck driver and he left me and my wife and kid on the side of the road. that was after we waited for an hour for him. he got pissed cus he wanted to hook the trailing arm and i wouldnt let him. he told me not to tell him how to do his job. but its my friggin car (IMG:style_emoticons/default/chair.gif) . anyways... a friend brought me a fuel pump and we were able to drive it home.
i have the aaa 100 mile tow also, but that is for catastrophic failures. i was just adding the clutch tube repair kit to my spares and was wondering what other guys carry. towing is the final option for me. i try to keep my car clean and top shape. most of the time i can slip on my coveralls and have it fixed in minutes....instead of waiting an hour for the tow truck. hmmmm? a small test light maybe..... or better yet, a cheapy multi meter. |
RickS |
Mar 21 2012, 11:49 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
AAA card and a Visa - I know it's cheating. Also fuses, zip ties, plugs, belt, relays, a full tool kit, jack, fix a flat, and a couple of LEd flashlights
Bartlett 914 |
Mar 22 2012, 07:57 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Spare cone screw, Ignition igniter and a fuel pump.
TheCabinetmaker |
Mar 22 2012, 08:06 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have a pretty extensive set of stuff that I take on long trips, but for eveyday around town, Nothing. Not trying to be a smartass, I just have that much confidence in my car.
jcambo7 |
Mar 22 2012, 09:12 AM
Senior Member Group: Members Posts: 1,669 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I have a pretty extensive set of stuff that I take on long trips, but for eveyday around town, Nothing. Not trying to be a smartass, I just have that much confidence in my car. Smartass (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
mrbubblehead |
Mar 22 2012, 09:18 AM
I have a pretty extensive set of stuff that I take on long trips, but for eveyday around town, Nothing. Not trying to be a smartass, I just have that much confidence in my car. yep, i have complete confidence in my car also....i drive mine back and forth to las vegas every week. its about 600 miles round trip. you have to be confident to take an aircooled car thru the blistering/freezing desert like that.....but it is still there- the what ifs. |
TheCabinetmaker |
Mar 22 2012, 09:39 AM
I have a pretty extensive set of stuff that I take on long trips, but for eveyday around town, Nothing. Not trying to be a smartass, I just have that much confidence in my car. yep, i have complete confidence in my car also....i drive mine back and forth to las vegas every week. its about 600 miles round trip. you have to be confident to take an aircooled car thru the blistering/freezing desert like that.....but it is still there- the what ifs. LOL. 600 miles qualifies as a long trip for me. My around town stuff may consist of only 4 miles a day from home to work, lunch and back, and work to home. If I breakdown on the way to work, I can coast to the shop. (IMG:style_emoticons/default/smile.gif) |
jcambo7 |
Mar 22 2012, 09:41 AM
I have a pretty extensive set of stuff that I take on long trips, but for eveyday around town, Nothing. Not trying to be a smartass, I just have that much confidence in my car. yep, i have complete confidence in my car also....i drive mine back and forth to las vegas every week. its about 600 miles round trip. you have to be confident to take an aircooled car thru the blistering/freezing desert like that.....but it is still there- the what ifs. LOL. 600 miles qualifies as a long trip for me. My around town stuff may consist of only 4 miles a day from home to work, lunch and back, and work to home. If I breakdown on the way to work, I can coast to the shop. (IMG:style_emoticons/default/smile.gif) Oh yeah good ol' Tulsa...Everything is within walking distance. (IMG:style_emoticons/default/poke.gif) P.S.-I don't miss Oklahoma... (IMG:style_emoticons/default/biggrin.gif) |
TheCabinetmaker |
Mar 22 2012, 09:50 AM
I have a pretty extensive set of stuff that I take on long trips, but for eveyday around town, Nothing. Not trying to be a smartass, I just have that much confidence in my car. yep, i have complete confidence in my car also....i drive mine back and forth to las vegas every week. its about 600 miles round trip. you have to be confident to take an aircooled car thru the blistering/freezing desert like that.....but it is still there- the what ifs. LOL. 600 miles qualifies as a long trip for me. My around town stuff may consist of only 4 miles a day from home to work, lunch and back, and work to home. If I breakdown on the way to work, I can coast to the shop. (IMG:style_emoticons/default/smile.gif) Oh yeah good ol' Tulsa...Everything is within walking distance. (IMG:style_emoticons/default/poke.gif) P.S.-I don't miss Oklahoma... (IMG:style_emoticons/default/biggrin.gif) Uh, not really. Its about 20 miles from my house to south tulsa. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/drunk.gif) |
914.SBC |
Mar 22 2012, 11:10 AM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
I carry a mere AAA Card and an AMEX.
monkeyboy |
Mar 22 2012, 11:20 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Since the car is really too low to get under, and my fuel pump is under the tank... Just my AAA card, some fuses, and a couple of relays. I do have a couple of screwdrivers to tighten something up too.
Lo-Fi Version | Time is now: 27th September 2024 - 06:36 AM |
