What is this sensor, and why isn't it connected?? |
turk22 |
Aug 15 2012, 08:49 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Black22 |
Aug 15 2012, 08:53 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
It looks like the CHT to me. Car is probably running rich, and it likes it!
CG-914 |
Aug 15 2012, 09:19 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
It looks like the CHT to me. Car is probably running rich, and it likes it! (IMG:style_emoticons/default/agree.gif) it is the cylinder temperature sensor. It is an major part of your D-Jet. Hook it up and go from there! It will improve your mpg! |
turk22 |
Aug 15 2012, 09:26 PM
Wow, I thought I had read in other threads that the car wouldn't even run if that was disconnected?
Does anyone have a picture of where is connects at? Haven't had much luck searching for it... thx, Turk |
Dave_Darling |
Aug 15 2012, 10:59 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The stock CHT should be under a hole that is just out of sight in that picture. The thin black wire that crosses the spark plug connector looks like it is going to the stock sender.
The arrowed sender could be a CHT on a spacer. It isn't original to the 914; if it is the setup on the spacer I think it is a Bus part. If the original CHT is connected, the one in your picture is not really needed. If no CHT sender is connected at all, the engine will run very rich. Usually rich enough to not run at all, but there are exceptions. Especially if other things have been adjusted to make the mixture very lean. The stock sender wire runs to a thin rectangular plastic box connector, on a wire that goes into the FI wiring harness right near there. --DD |
McMark |
Aug 16 2012, 10:13 AM
That picture kinda looks like you have two installed. Is there a wire coming out from a hole next to the spark plug there?
turk22 |
Aug 16 2012, 11:15 AM
The stock CHT should be under a hole that is just out of sight in that picture. The thin black wire that crosses the spark plug connector looks like it is going to the stock sender. The arrowed sender could be a CHT on a spacer. It isn't original to the 914; if it is the setup on the spacer I think it is a Bus part. If the original CHT is connected, the one in your picture is not really needed. If no CHT sender is connected at all, the engine will run very rich. Usually rich enough to not run at all, but there are exceptions. Especially if other things have been adjusted to make the mixture very lean. The stock sender wire runs to a thin rectangular plastic box connector, on a wire that goes into the FI wiring harness right near there. --DD That picture kinda looks like you have two installed. Is there a wire coming out from a hole next to the spark plug there? I think your both right, there is that other wire, coming from behind the Manifold tube, that runs thru a hole in the tin. It does appear to be connected, so I'll trace it and see where it goes. If I'm hearing you guys right, this sensor may be an add on by PO, that may be redundant? |
McMark |
Aug 16 2012, 11:56 AM
If that's true, the one you can see is irrelevant. Leave it, remove it, whatever floats yer boat.
CG-914 |
Aug 16 2012, 12:06 PM
I thought it was a wired spot (IMG:style_emoticons/default/dry.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 07:44 AM |
