Stalling after a few minutes |
Shindog1961 |
Dec 2 2012, 03:09 PM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
My 74 2.0 will idle about 1200 right after starting, but the idle speed will drop after a few minutes, to rpms low enough that it will stall if I don't keep on the gas. I was adjusting the throttle cable when it broke. While I am changing that out, any thoughts on other things to check? Last fuel pressure about 6 months ago, tune up at the same time. Vacuum lines replaced about 3 months ago.
914itis |
Dec 2 2012, 03:25 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
My 74 2.0 will idle about 1200 right after starting, but the idle speed will drop after a few minutes, to rpms low enough that it will stall if I don't keep on the gas. I was adjusting the throttle cable when it broke. While I am changing that out, any thoughts on other things to check? Last fuel pressure about 6 months ago, tune up at the same time. Vacuum lines replaced about 3 months ago. Start with fuel pressure test. |
JawjaPorsche |
Dec 2 2012, 03:26 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Just checking. Does it idle at 800? If not adjust idle screw. I assume you have FI.
Jeffs9146 |
Dec 2 2012, 09:31 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
If it is FI then I would check the CHTS!
McMark |
Dec 2 2012, 09:45 PM
Kinked fuel lines under the tank?
Shindog1961 |
Dec 2 2012, 10:22 PM
Thanks! I will check them all.
Lo-Fi Version | Time is now: 27th September 2024 - 11:45 AM |
