FS-aux air valves, SS trans, FB front valance,, ... |
lynch |
Jan 22 2013, 06:35 AM
Newbie Group: Members Posts: 34 Joined: 9-September 06 From: Saline, Michigan Member No.: 6,806 |
There are too many to post at once. I'll post pictures for items as they are requested.
I cleaned the side shift transmission & rear valance, everything is in "as-received/as-removed" condition. I will only check the site once or twice a day. If you want a faster response, send me a PM as I seem to get those more quickly. Prices do not include shipping. Shipping costs are extra. If you know of a good way to ship items economically, tell me. If you have a preference, tell me. Do not assume I know. I use USPS or UPS Store. Items marked (PITA to ship), mean I lose a lot of time to package and (or drive 20 miles to) ship and is somewhat compensated in price. Many of the "excellent" parts were removed from a 1972, 1.7, from Ohio that was parked in ("Mom's") garage since 1979 when the Hell hole rotted. Balance of parts were from the four 914's it took to make one. Evaporation Tank, 1972 (excellent - slightly dirty not crusty) $50 Steering column assy, 1972 (no ignition switch) $50 Tan Driver side Pocket & PS armrest, 1974 (driver condition) Dash facade - backetweave, 1972 (excellent) Odometer reset cable assembly, complete $15 Fuel tank filler, 1972, (very good exterior, but rusted under gas cap from very stale fuel) Headlight motors, 1972, $40 pair Air cleaners, oil bath, 1970-1972, $40 (PITA to ship) Front air dam, fiberglass, P/P Products (two small cracks from parking too far forward) $90 (PITA to ship) Airduct, Defrost assembly, 1972 (complete, excellent) $100 Airduct, Defrost control, 1972, (nice) $35 Rain tray drain tubes (one broken ear, no other cracks) $20 Front license plate brackets (may not be for 914) $5 each Door straps (prevent door from over-extending (one good, one very-good/excellent) $20 pair Door latch mechanisms, 1972 (no rust, not worn out), $40 pair Door Passenger, 1972, solid, straight (surface rust removed & treated) $125 (PITA to ship) Rubber intake elbow between air cleaner & throttle, from 1.7 1972, $5 each Roll bar Pad, 1972, (minor cracking by two screw holes, nice daily driver quality), $40 (PITA to ship) 1.7 Intake manifold with Temperature sensor, cold start injector, Aux air valve, throttle, TPS, $85 Intake mounting bracket for 1.7, 1972 (holds air cleaner on case), $10 1.7 Intake manifold with temperature sensor, cold start injector, Aux air valve, $60 Throttle with Throttle Position Sensor, from 1.7, 1972 (1 of 2) $25 Throttle with Throttle Position Sensor, from 1.7, 1972 (2 of 2) $25 Aux air valve (believe it is for 2.0L as is same as a 2.0L Type-IV bus) $35 Glove box, 1972 (excellent, no holes, no rot, minor wear) $25 Glove box door with basket weave, 1972 (excellent) $25 Monza muffler for 1.7, 1.8, upright muffler, $50 (PITA to ship) Monza muffler for 1.7, 1.8, horizontal muffler, $50 (PITA to ship) Rear trunk release solenoid, $30 Rear trunk spring loaded latch, (excellent) $5 Motor mount for Side shift configuration, with attach point for the engine, $100 (PITA to ship) Side shift, transmission (leaks at speedometer drive seal/o-ring) $350 (PITA to ship) Side shift, shifting rod aft of firewall, $25 Side shift, gear shift with knob, $40 Side shift, connector between shifting rod and transmission linkage $20 Targa Hold down point and hook for front of Targa top $10 Targa top $35 (PITA to ship) Rear trunk lid (one good w/o rust $40, one driver w/rust - free) Pick up only - Ann Arbor, Michigan, 48108 Front trunk lid - $10 Pick up only - Ann Arbor, Michigan 48108 Jack hold down straps, $10 Rear glass (1 of 2) (no defrost wires, boxed, ready to go) $20 Rear glass (2 of 2) (no defrost wires, loose, pickup only) $5 PS window regulator, early style, $15 (PITA to ship) Knee pads, 1972, (very good/excellent with metal strips) $50 each (PITA to ship) (IMG:style_emoticons/default/welcome.png) Attached thumbnail(s) Attached image(s) |
saigon71 |
Jan 22 2013, 07:36 AM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Manifold Pressure Sensor (MAP) 0280100049 (sealed, holds vacuum) $35
PM Sent |
lynch |
Jan 22 2013, 07:39 AM
more pictures
Attached thumbnail(s) |
gcrotvik |
Jan 22 2013, 07:54 AM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Interested in "914/4 Billstein jack (1974) $35." Could you post a picture?
Thanks, Greg |
lynch |
Jan 22 2013, 07:59 AM
Jacks are sold & shipped to Jerry
lynch |
Jan 22 2013, 08:03 AM
Sail trim is sold.
gcrotvik |
Jan 22 2013, 08:14 AM
Hi Neil,
The top picture is the 74. Sorry, I was hoping it was in better shape than the one I already have. My jack is in better shape so I will pass. Thank you and good luck with you parts sale. You have lots of great part at great prices. Greg Here are the pictures of the two later model jacks. As I do not remember which was the 1974, specify whether you want the one with the "wedge" handle or the "offset". Thanks, Neil Interested in "914/4 Billstein jack (1974) $35." Could you post a picture? Thanks, Greg |
914ltd |
Jan 22 2013, 08:32 AM
Member Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
PM on both shift covers, upped the price on the too cheap early one.
lynch |
Jan 22 2013, 08:39 AM
913B |
Jan 22 2013, 09:11 AM
Senior Member Group: Members Posts: 851 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Interested on the fog lights, can I get close up pic of both glasses please. Thanks
913B |
Jan 22 2013, 09:14 AM
Interested on the rear calipers cores. Price ?? I may want to combine the shipping if I can
lynch |
Jan 22 2013, 02:00 PM
Fog light Lenses are "TN4"
brant |
Jan 22 2013, 02:11 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
email sent...
oops... I want another item too and I have another question too |
lrdegree |
Jan 23 2013, 09:54 PM
I'm new here ... Group: Members Posts: 0 Joined: 22-March 10 From: Riverside, California Member No.: 11,487 Region Association: Spain |
How much for the rear valance ? Thanks
lynch |
Jan 23 2013, 10:13 PM
Markl |
Feb 11 2013, 11:40 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
PM sent
lynch |
Feb 12 2013, 05:36 AM
Old Bilstein jack & Rear valance sold locally
hulken |
Mar 18 2013, 11:35 AM
Newbie Group: Members Posts: 1 Joined: 14-March 09 From: Norway Member No.: 10,161 Region Association: None |
Interested in odometer reset cable If not sold? Living overseas i Norway, I hope you're shipping overseas?
Robert21 |
Mar 18 2013, 10:46 PM
ron21 Group: Members Posts: 288 Joined: 9-July 04 From: Seal Beach Ca 90630 Orange co Member No.: 2,330 Region Association: None |
I,am looking for a Auxlary air Regulater It the that has a wire at the bottom . If thats the one you i will buy it ,. thanks
lynch |
Mar 19 2013, 08:53 AM
Asking about aux air valve, it this the one you are looking for?
----- Odometer reset inquiry: send my your address and I will your shipping cost. --------- Roll bar pad inquiry, picture follow Attached thumbnail(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:46 AM |
