> 8" 951 Fuchs on a narrow body, Is it possible??? Pics and tire sizes requested!!!
bigkensteele
post Feb 3 2013, 12:27 AM
Major Member
I picked up a set of 951 Fuchs today, 7&8 x 16. They are ugly, which is fine by me as I would like to have them blasted and do an RSR finish.
Search tells me that they have been fit to narrow body cars, but I would like to know what must be done in the rear to make them fit. I would also appreciated pictures and get some insight on tire sizing as well as ideas for spacers for the front.
Thanks,
Ken
Dave_Darling
post Feb 3 2013, 12:37 AM
914 Idiot
It can be tough to fit 7s under stock fenders. I think 8s would be impossible. Of course, tire sizes and alignment settings and the exact offset of the wheels make a difference, as well as individual chassis differences. So it's never quite safe to say "impossible"...
Be prepared to have to modify the rear fenders to at least some extent. They may need to be pulled or rolled outward, or possibly even cut and patched.
--DD
Mike Bellis
post Feb 3 2013, 12:49 AM
Resident Electrician
You just need to roll the fenders. Esatwood makes one that will work with a little tweeking.
bigkensteele
post Feb 3 2013, 12:54 AM
Major Member
QUOTE(Dave_Darling @ Feb 2 2013, 10:37 PM) *
--DD
Thanks, Dave.
I probably should have stated that I am at a cross-road right now. I have AA repro flares. I have a set of 911 6&7 x 16 Fuchs as well as the 944 set. I can probably pull off whatever combination I want to try. However, I LOVE the look of HaroldD's car.
If I could pull that off, I would probably sell the flares.
Mike Bellis
post Feb 3 2013, 12:57 AM
QUOTE(bigkensteele @ Feb 2 2013, 10:54 PM) *
They look rolled it that pic... I have been told you can stretch them a full inch with the roller.
bigkensteele
post Feb 3 2013, 01:05 AM
Major Member
QUOTE(kg6dxn @ Feb 2 2013, 10:57 PM) *
That is the same guarantee I got when I bought that pump from the back-pages of Playboy! (IMG:style_emoticons/default/confused24.gif)
sixnotfour
post Feb 3 2013, 01:58 AM
Harold's 914-6 is awesome, but if lowered he would be rubbing, I had them on a 914 that was low , I started with 7's a bit of fender rolling with a 1x2 wood board, A while later switch to the 16x8 951's and had to go a bit more same method. I don't know if the roller would work as the rear fender is not a true radius.
speed metal army
post Feb 3 2013, 02:04 AM
Waiting for the rain to stop...
6" Look nice on a narrow body....
sixnotfour
post Feb 3 2013, 02:22 AM
Finally found a pic of what it takes to run em, 245/45x16 951's, the burnt paint is from years of different wheel combos.
FYI my car now restored to stock.
sixnotfour
post Feb 3 2013, 03:23 AM
I made these for my sons Golf and I ended up with because he had to have 17's ???
16x6's widened to 7.5.. 1.5 inch added to the inside and a spacer.......7's would be perfect,
HaraldD
post Feb 3 2013, 06:49 AM
Region Association: Germany
Hi,
here are 2 Fotos of my car. It is maybe 1 inch each side, but it`s enough. If you don`t know it - you don`t see it... (IMG:style_emoticons/default/smile.gif)
Regards
Harald
914Sixer
post Feb 3 2013, 08:38 AM
With the flares you can put 8" on each corner with no problem. I have even seen 9" on the rear with the right tire combo.
Woody
post Feb 3 2013, 12:18 PM
Sandbox Rabblerouser and head toilet scrubber
QUOTE(914Sixer @ Feb 3 2013, 08:38 AM) *
I'm running 10s (IMG:style_emoticons/default/poke.gif)
carguy914
post Feb 3 2013, 01:03 PM
The 951 Fuchs have a different offset and may work ok, (tire size is everything) if you notice the lug nut holes are recessed and the 7" wheel for the front look more like a 6" 911 wheel on the face, and the same for the rear 8"...looks more like a 7" 911 most of the extra width is on the backside...so it's back to some 914's will accept 911 7" at the rear and some won't and it crazy from side to side.
Spoke
Jerry
I put 7x15 and 8x15 on my 74. Had to pound out the rear fenders to work.
carr914
post Feb 3 2013, 01:08 PM
Racer from Birth
If you give up on the 8"s, let me know I need a set
brant
post Feb 3 2013, 01:23 PM
how wide are Harold's rear rims though?
here are 7inch fuchs with 911 offset
(different offset)
these have 1 inch spacers and still plenty of room
I have test fit 8's on the car and honestly might be able to run 8's with some spacer
but the fenders are VERY worked over and not stock at all:
brant
post Feb 3 2013, 01:24 PM
here are 6inch rims with no spacer as a test:
brant
and 7inch fuchs with no spacer:
914Eric
post Feb 3 2013, 01:44 PM
To the dark side you go.
(IMG:style_emoticons/default/alien.gif)
- Lo-Fi Version Time is now: 23rd November 2024 - 01:39 AM
