anyone ever break a bilstein?, I think I did! |
tadink |
Feb 4 2013, 04:31 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
so, going down my bumpy road into town sunday morning - I rounded a corner and went over a bump and BANG - something gives way in the rear. I pull over and look around and can't find anything - so I continue on my way and there is a noticeable clunk on each bump coming from right rear - can't tell just where.
I pick up the chicken wings (no shortage!) and head back up the hill and the clunk gets worse and I start to notice some handling - shock absorber weirdness.....almost home, and then the right rear tires starts to make contact with the inner wall of the car and the apparently "not cut far enough" remnants of the rear quarter panel. Jacked her up - pulled off the tire and wow - it appears the bilstein has failed! Top plastic torn part way off, puddle of oil below. What gives? I don't see anything else amiss under there - do they just fail like this? I can push down on the right rear and there is only spring - no shock absorption whatsoever, and the clunk. Not sure what is clunking actually - maybe the guts of the shock? they were a new-ish set of shocks, I'm told by the PO, and running well up to the Bang-clunk experience. I guess I'm in the market for a new shock? thoughts? (IMG:style_emoticons/default/confused24.gif) td |
Eric_Shea |
Feb 4 2013, 04:39 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Kinda rare. But... "Tire Rubbing"??? How's your inner suspension ear?
monkeyboy |
Feb 4 2013, 04:48 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Looks like you blew the lid off it. I have seen off road shocks do that, but only when the massively bottom out.
tadink |
Feb 4 2013, 06:38 PM
weeeeellll there is more to the story -
I think that the top nut came off, then when I went over a bump the shock top pulled out and rattled around loose - the weight of the car must have kept stuff sorta in place - but I imagine there was some torque on the strut and that must have blown a seal. the strut top was pulled down a few rungs on the spring - have a look at the pic. morale of the story - let's all go our and check the tension on those nuts! <do I get bonus points for working out a "McGiver-solution" on a spring-tensioner?> so, one blown shock, I'll pick up a pair so I have a matched set. sigh. cheers all - its only money! (IMG:style_emoticons/default/beer3.gif) td |
eric9144 |
Feb 4 2013, 08:22 PM
Advanced Member Group: Members Posts: 2,739 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Bilstien HQ is in SoCal, nearly next door to where I work, they do repair and revalve work there, you might want to contact them. Might be cost effective to go that route...
ThyssenKrupp Bilstein of America 14102 Stowe Drive Poway, CA. 92064 1-858-386-5900 |
Lo-Fi Version | Time is now: 27th September 2024 - 09:44 AM |
