Fuel Tank fitting washer, Are they readily available? |
JawjaPorsche |
Feb 17 2013, 07:11 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I am planning to replace my plastic tunnel fuel lines soon. Needless to say, I am going to pull the fuel tank. I am going to replace the strainer screen for the fuel tank. I will probably need to replace the fitting washer while I have it off. Can I get this rubber washer at a good hardware store? I don't want to have a leak after putting everything together!
Thank you in advance for your help and response! (IMG:style_emoticons/default/biggrin.gif) |
walterolin |
Feb 17 2013, 07:42 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
As you noted a few days ago, don't discount AA. Gaskets are copper, two sizes. Go to the "914 Fuel Tank Parts" page, look at #'s 10, 11, and 13. 10 is the strainer. I got all three a few weeks back.
Olin |
JawjaPorsche |
Feb 17 2013, 07:46 AM
As you noted a few days ago, don't discount AA. Gaskets are copper, two sizes. Go to the "914 Fuel Tank Parts" page, look at #'s 10, 11, and 13. 10 is the strainer. I got all three a few weeks back. Olin Thanks a million, Olin. I really appreciate you pointing me in the right direction. (IMG:style_emoticons/default/beerchug.gif) |
TheCabinetmaker |
Feb 17 2013, 08:18 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
They are also available at the bus depot, the Bughaus , Vw parts houses, cip1, most independent pcar shops, etc.
Nozzle |
Feb 17 2013, 08:26 AM
Member Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region |
Do these copper washers require any other sealant? When I removed mine they both had some sort of gasket sealer applied to the threads by the previous owners mechanics.
Rotary'14 |
Feb 17 2013, 09:22 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
Actually the original sealing washers are made of fiber. I believe the engineers were worried about an electrolytic reaction between the steel tank to the copper washer, to the aluminum tank nipple.
I have some for sale for $1 (for 2) plus postage. -Robert |
JawjaPorsche |
Feb 17 2013, 10:00 AM
Actually the original sealing washers are made of fiber. I believe the engineers were worried about an electrolytic reaction between the steel tank to the copper washer, to the aluminum tank nipple. I have some for sale for $1 (for 2) plus postage. -Robert pm sent |
Elliot Cannon |
Feb 17 2013, 06:14 PM
I installed Teflon washers eight years ago and they work great.
Nozzle |
Feb 17 2013, 08:03 PM
Actually the original sealing washers are made of fiber. I believe the engineers were worried about an electrolytic reaction between the steel tank to the copper washer, to the aluminum tank nipple. I have some for sale for $1 (for 2) plus postage. -Robert PM sent. |
Lo-Fi Version | Time is now: 27th September 2024 - 11:01 AM |
