What I did today, Removed tar from interior floorboards |
watsonrx13 |
Nov 21 2004, 06:02 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well it was a perfect day in sunny Florida (finally) so I decided to get some work done on the teener. Today the objective was to remove the tar from the interior floorboards.
Here's the before pic: 1 of 4 Attached image(s) |
watsonrx13 |
Nov 21 2004, 06:03 PM
I used an air-hammer and a short chisel. It took me about 3 hours to completely remove the tar. Here's a shot after 30 min removing the tar from underneat the passenger's seat.
2 of 4 Attached image(s) |
watsonrx13 |
Nov 21 2004, 06:04 PM
Next I needed to remove the seam-sealer and the residual tar. I used an angle-grinder with a huge wire-wheel (I completely wore the wire wheel out and will need to replace it). I also used several screw-drivers to remove the seam-sealer in the tight corners.
3 of 4 Attached image(s) |
watsonrx13 |
Finally, I cleaned the floor and covered it with Ospho to protect it until I can paint. I still have the pedal area floorboard to finish cleaning, along with center tunnel.
Not bad for 8 hrs work. 4 of 4 Attached image(s) |
Series9 |
Nov 21 2004, 06:09 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
If you use a propane torch and a putty knife, that tar comes up a little easier.
Jeroen |
Nov 21 2004, 06:31 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
nice job!
looks like there are no new nasty surprises |
watsonrx13 |
Nov 21 2004, 06:39 PM
No, it was very clean, but since I was in there...
Once I finish with the interior, I'm going back over the engine compartment and rear trunk to check anything I might have missed. Then I'm going to paint these areas, looking at end of Dec/early Jan. Anyway, that's the plan for now (subject to change without prior notification... (IMG:style_emoticons/default/wacko.gif) ) |
Lo-Fi Version | Time is now: 27th September 2024 - 03:29 PM |
