New Master Cylinder resevoir |
Harpo |
Apr 9 2013, 04:29 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Considering that I had a new master cylinder and all new calipers I thought I should get a new reservoir. Especially when there was 38 years of residue inside my master cylinder reservoir. Low and behold the part is still available.
Here is the problem the new reservoir did not come with the short (3 inch) flex lines. What can I use for these that is compatible with brake fluid. Thanks |
7TPorsh |
Apr 9 2013, 04:36 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I used fuel line hose...
gms |
Apr 9 2013, 04:37 PM
Advanced Member Group: Members Posts: 2,701 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
part number is 999-181-021-50-M107
I believe Pelican sells by the meter interesting that they have the early style with the venting nipple |
LotusJoe |
Apr 9 2013, 04:40 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Auto Atlanta has the hose
R99918102150 - Replacement/OEM |
gms |
Apr 9 2013, 04:41 PM
Harpo |
Apr 9 2013, 04:48 PM
There is a comedian in every bunch
Cap'n Krusty |
Apr 9 2013, 05:58 PM
They still have some? I thought they gave the hose to everybody! The Cap'n BTW, the nice guys at GPR carry it, too, and they're our friends ......................... |
913B |
Apr 9 2013, 06:17 PM
Senior Member Group: Members Posts: 851 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
That clear plastic line for overflow ? I read from someones build thread was to go to Petsmart or your favorite pet supply store and use the clear pvc for air in the aquariums, thats what I did fits just right, but it wasnt a 3 inch, more like 2-3 feet needed.
Harpo |
Apr 9 2013, 06:36 PM
Not the 1/8 line but the two nipples on the left that go down to master cylinder
I will check GPR Thanks David |
914Sixer |
Apr 9 2013, 08:36 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Any bug shop has the brake line hose.
Mikey914 |
Apr 9 2013, 09:09 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just a heads up. With the overflow you can't pressure bleed. You may want to plug it, because really, do you need an overflow?
McMark |
Apr 9 2013, 09:11 PM
You can probably find it locally, but if you can't I'll snip off a couple of pieces and drop them in an envelope.
dfrank |
Apr 10 2013, 05:51 AM
Newbie Group: Members Posts: 14 Joined: 28-December 12 From: High Point, NC Member No.: 15,295 Region Association: MidAtlantic Region |
Where did you get the reservoir?
Harpo |
Apr 10 2013, 11:36 AM
I got it from Stoddards for $43.00
Racerchris is sending me a short section |
reharvey |
Apr 10 2013, 12:51 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Just a heads up. With the overflow you can't pressure bleed. You may want to plug it, because really, do you need an overflow? (IMG:style_emoticons/default/agree.gif) I would plug that vent hole. Why let moisture into your brake fluid. |
gothspeed |
Apr 10 2013, 07:43 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
This is the VW brake line that I used:
http://www.ebay.com/itm/VW-Volkswagen-Blue...b1e&vxp=mtr Here is a pic of it: |
Drums66 |
Apr 11 2013, 03:14 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 27th September 2024 - 12:55 PM |
