Gas tank, Sock |
Gas tank, Sock |
gunny |
May 16 2013, 02:30 PM
Member Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
Is the sock on the fuel supply side or the return side? I thought I knew but when I took the tank out the PO had the lines crossed. I thought that the sock should be on the supply side.
Jeffs9146 |
May 16 2013, 02:45 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Is the sock on the fuel supply side or the return side? I thought I knew but when I took the tank out the PO had the lines crossed. I thought that the sock should be on the supply side. Yep! (IMG:style_emoticons/default/agree.gif) |
Type 47 |
May 16 2013, 08:26 PM
Senior Member Group: Members Posts: 784 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
what is "the sock"?
worn |
May 16 2013, 08:51 PM
can't remember Group: Members Posts: 3,290 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
rhodyguy |
May 17 2013, 08:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the sock is located inside the tank on the supply outlet. you have to remove the capturing nut to change them out. when the tank is empty you can look inside to see its condition. chances are you have a build up of debris in the shallow well that surrounds the outlet if the tank has not been serviced in recent history.
Type 47 |
May 18 2013, 11:36 AM
Which one is in and out? where does the sock go? this is a 75' tank from a 62k mile car, only time tank has been out of car.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1368898563.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1368898564.2.jpg) |
walterolin |
May 18 2013, 12:00 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
On my 1970, the return is the one closest to the center line, and the supply line is larger than the return. I don't think the sock will go into the return, and there is a baffle just inside the intake which would block it anyway.
The real problem will be the two nuts, they are aluminum, and the threads on the tank are steel, which likely will be rusted under the aluminum. When I took my nuts off, the aluminum stripped and stuck to the steel, I had to buy new nuts - they are different sizes, I found them at AA. And while you are there get the nonmetal gaskets. From your photo, it looks like both of your lines are the same size, the '75 might be different from mine. Then you have to clean up the threads on the tank fittings. I couldn't find a chaser, and it took a long time with a machinist's scribe and a Dremel to pick out all of the aluminum and clean out the rust. The new nuts will be aluminum too, and you can't use them for a chaser because they are too soft. The PET at AA calls them "union nuts" and shows two different nuts for all years. http://www.autoatlanta.com/porsche-parts/p...arts/201-00.php |
bcheney |
May 18 2013, 12:01 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Which one is in and out? where does the sock go? this is a 75' tank from a 62k mile car, only time tank has been out of car. (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1368898563.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i139.photobucket.com-11790-1368898564.2.jpg) I don't remember which is which from external visual. Loosen the nut on each and remove. You will then see which has the sock. Additonally, I think there is a small basin around the supply side inside the tank. |
r_towle |
May 18 2013, 01:36 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you can see both of them in the pick
The tall this IS the sock. The hole to the left is the return. Rich |
Drums66 |
May 18 2013, 02:33 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....I leave it out!(dirty sock) & use filter's (IMG:style_emoticons/default/shades.gif)
(IMG:style_emoticons/default/bye1.gif) .......That's just me! |
r_towle |
May 18 2013, 07:31 PM
New socks are readily available at your favorite vw bus store.
Rich |
Lo-Fi Version | Time is now: 27th September 2024 - 05:35 AM |
