Fuel lines |
Fuel lines |
jesiv |
May 20 2013, 07:16 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I need to remove/replace my sock. I have replaced every gas line except the plastic in the tunnel. So seems like an excellent time time to do it.
Question 1) if factory plastic are available and lasted 40 years why not stock. Otherwise it appears to be a consensus for Tangerine SS kit. Question 2) with the engine in what all do I need to remove to make it straight forward to replace the fuel lines? Pictures would help!! Is it really that straight forward threading SS hard lines through the required path. Don't want to start something that could take more than a day.... Regards James |
Rotary'14 |
May 20 2013, 07:24 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I need to remove/replace my sock. I have replaced every gas line except the plastic in the tunnel. So seems like an excellent time time to do it. Question 1) if factory plastic are available and lasted 40 years why not stock. Otherwise it appears to be a consensus for Tangerine SS kit. Question 2) with the engine in what all do I need to remove to make it straight forward to replace the fuel lines? Pictures would help!! Is it really that straight forward threading SS hard lines through the required path. Don't want to start something that could take more than a day.... Regards James It's do-able with the engine in,, but you must pull your fuel tank for the front part. There is a video of an installation in my for sale thread in the vendor's section,,, awww here, I'll save you some time. http://www.youtube.com/watch?v=hxFRQTWLetw Buy from whomever makes you more comfortable with. (IMG:style_emoticons/default/biggrin.gif) |
struckn |
May 20 2013, 08:29 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Plastic does not like Ethanol gas! Neither does old rubber. If it's a carb car you only need to run one line. Don't need the return line with Carbs. Fuel Bowl and Lower Pressure then FI.
Lo-Fi Version | Time is now: 27th September 2024 - 06:20 AM |
