SVDA - Does anyone have one installed?, And has a good picture of where the #1 spark plug wire is? |
ThePaintedMan |
May 28 2013, 06:40 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Okay,
Back to basics before I give up on this engine completely. I've had the SVDA dizzy on my car off and on throughout the year, and I recently re-installed it. As per my other thread, the car runs but simply falls on it's face and backfires like crazy at 4,000 rpm. I'm beginning to wonder if I've had my wires installed 180 degrees out the whole time. I understand the process of finding TDC on #1, and that the rotor should be pointing toward the #1 spark plug wire when everything is hunky-dory. I've used multiple resources, but the process is explained here: http://www.hot-spark.eu/docs/Installing-SVDA-034.pdf The problem that no one ever seems to acknowledge is that the distributor turns. So when I have the engine at TDC, how do I know the rotor is pointing at the true #1 spark plug wire? If I turn the dizzy 90 degrees to the left or the right, I'm at a different plug wire. What would really help me is if someone who has an SVDA installed would post a picture and point out where #1 is on their setup. Sorry, but I have a habit of making the really simple things far too complicated. But I thank you for your help. (IMG:style_emoticons/default/pray.gif) |
michael7810 |
May 28 2013, 08:00 PM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
"Sorry, but I have a habit of making the really simple things far too complicated." You got that right.
If you can turn the distributor so the rotor lines up with No 1 on the cap at TDC, set the timing and you're good to go as long as the wires are on the cap in the proper firing order. Sorry I don't have a picture but when looking from the rear of my car forward the No 1 wire is approx 1 o'clock on the cap and the vacuum advance unit is approx 9 o'clock. |
ThePaintedMan |
May 28 2013, 09:09 PM
Thanks Michael. I went back out and reset everything as you described. I'll try to start it tomorrow and re-time it and report back. (IMG:style_emoticons/default/beerchug.gif)
rhodyguy |
May 29 2013, 07:38 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
well, it's tomorrow what happened?
KaptKaos |
May 29 2013, 05:39 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I believe that my SVDA has #1 at about 7 o'clock (12 o'clock being towards the front of the car). Putting it at 11 o'clock, like on my old dizzy didn't give me the freedom to turn the dizzy as the vacuum can got hung up on the tin.
ThePaintedMan |
May 29 2013, 07:23 PM
Spoke with McMark before I tried setting this thing up again and it all made perfect sense. Started right up after I set TDC and all the plug wires right. Timed it once again, this time at around 30 degrees total advance, since I don't have vacuum advance hooked up. Runs great at low and mid range RPMs, with a nice smooth transition through the idle-main circuit. Unfortunately the backfire is still there, strong as ever.
But thank you guys for helping me ensure the dizzy was right at least (I think it was all along). |
r_towle |
May 29 2013, 07:45 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I wish you lived closer so I could fix this.
Can you post a video? Did you rebuild the motor? Rich |
messix |
May 29 2013, 07:55 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
this is an "old" motor?
the valve springs could be about done or broken, or a slightly bent valve that is hanging up at high rpm. |
ThePaintedMan |
May 29 2013, 08:06 PM
Hehe, I wish we all lived closer! (IMG:style_emoticons/default/beerchug.gif) I'd like to meet all of you guys someday, and knowing that's probably not going to every happen really depresses me sometimes (IMG:style_emoticons/default/sad.gif) Oh well.
This is indeed an old motor. The numbers I have for compression indicate it *may* have some life left (110 PSI on all 4) but I'm not holding out hope. I have no idea if, or when it has been rebuilt, but certainly not by me. Everything I know makes me believe it is the original, with over 100,000 miles and probably not rebuilt - there were no rebuild tags or markings on the engine when I got the car. Rich - I'll post a video sometime this weekend. I've got a GoPro, and as long as I keep the windows up, it should get pretty good sound. |
r_towle |
May 29 2013, 08:07 PM
Please list the carb specs for venturis and jets again.
Rich |
r_towle |
May 29 2013, 08:11 PM
And please post a few pics of the carbs on the car, with linkage attached.
McMark |
May 29 2013, 11:39 PM
Good thought. Have you confirmed sync of the carb both at idle and off-idle?
KaptKaos |
May 30 2013, 09:49 AM
Backfire when? On decel thru exhaust? Rich. Thru carbs? lean.
Do you have access to an LM1 or LM2? Seeing your A/F ratio will help you a lot. Glad you got the dizzy running! |
rhodyguy |
May 30 2013, 11:30 AM
does SVA HAVE a vac canister on it? what did you plug the ports on the carbs with?
monkeyboy |
May 31 2013, 08:49 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
At this point I'd be looking to yank the motor and do a tear down. You have swapped induction and ignition and neither has solved your problem.
I'm beginning to wonder if your heads aren't shot. Have you performed a leakdown test on this motor? |
Lo-Fi Version | Time is now: 27th September 2024 - 12:50 PM |
