What Did I Break At Yesterday's AX? |
Joseph Mills |
Nov 29 2004, 06:59 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
I haven't broken at an AX in a long time. Doesn't feel good at all.
On my third run when I attempted to launch my car in a robust manner at the start line, something popped, and I came to a rolling stop. I thought it had just popped out of low gear, but when I put it in reverse to backup to the start line, it would not move. Poor thang. (IMG:style_emoticons/default/biggrin.gif) We rolled it off the grid and began investigating. At first the clutch felt odd, but then I decided it felt "normal" to me. The shifter moved freely into all the proper gear selection spots. The end of the clutch cable at the tranny seemed to be moving properly. I started the engine with the clutch out and lever in neutral. Everything seemed normal. I slipped it into 4th gear and slowly let out the clutch. The car doesn't move and begins making a whirring sound with small tinny clicking/banging sounds. Doesn't sound good at all. I tried some other gear selections and it would sound a little different, but still similar. Seems like it's coming from the tranny. It sounds a bit like I have heard throw-out bearings sound when they go real bad. Here are some guesses and comments made by various people present (914 & non-914 people): "Sounds like the clutch". "Sounds like the tranny". "Sounds like the throw-out bearing". "I've never heard that sound before". "Sounds like you snapped the input shaft of the tranny. I've heard of that happening with a six, but not a four-banger". "Sounds expensive". None of the above sounded good to me. (IMG:style_emoticons/default/unsure.gif) I now know what happened, but I'm curious as to what some of you think may have happened. It could be something that was NOT mentioned above, or it could be something that WAS mentioned above. First correct answer wins a uh... I dunno. I'll think of something. Maybe just bragging rights. (IMG:style_emoticons/default/biggrin.gif) What's your best guess? |
bwilless |
Nov 29 2004, 07:03 PM
Member Group: Members Posts: 156 Joined: 24-January 03 From: Tempe, AZ Member No.: 192 |
CV Joint
Andyrew |
Nov 29 2004, 07:04 PM
clutch/pressureplate destroyed?
ohhh, the banging sound would give to the cv's... but anythings possible.. |
LvSteveH |
Nov 29 2004, 07:08 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
I second the CV joint
curtis |
Nov 29 2004, 07:11 PM
Member Group: Members Posts: 192 Joined: 14-June 04 From: Redlands,CA. Member No.: 2,206 |
mianshaft.
skline |
Nov 29 2004, 07:13 PM
My guess would be that you snapped the ring and pinion, that would be after the first guess of CV joint. Only one since you dont have a limited slip. It only takes one.
redshift |
Nov 29 2004, 07:14 PM
And you swear both axles are connected? (grab and yank)
Hmm... clutch, then transaxle... (please learn car phonics ie; rrRrrrR.... ssst ssst ssst sst... tdtdtdtdtdtdtdtdt.. and so on..) Sorry for ya buddy... I know that feeling.. M |
MattR |
Nov 29 2004, 07:16 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
QUOTE(joseph222 @ Nov 29 2004, 04:59 PM) "Sounds expensive" (IMG:style_emoticons/default/agree.gif) good luck! |
tesserra |
Nov 29 2004, 07:23 PM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
CV Joint.
Feels like something really serious but it is external of the trans and you should be happy it broke when you did not really need the car. ( I guess at the start of the autox the car is really needed) This is a great example of why everybody should Auto x. The car broke a part that was going to break anyway and it did not leave you in an unsafe place without help. Driving the car hard brings out symptoms that you may not notice in normal driving. George |
mightyohm |
Nov 29 2004, 07:26 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
CV joint, it's happened to me, TWICE!
The last time mine came off it whipped around and broke the clutch fork off. Not fun! I think all 914 owners are likely to have this happen at least once. |
skline |
Nov 29 2004, 07:28 PM
QUOTE(tesserra @ Nov 29 2004, 05:23 PM) CV Joint. Driving the car hard brings out symptoms that you may not notice in normal driving. George You mean you guys drive your cars hard?? I would never do that. (IMG:style_emoticons/default/wink.gif) |
bwilless |
Nov 29 2004, 07:31 PM
What did I win? A trip? How about a side view mirror? Joseph222 what happened? A friend wild9146 had this happen to his hot rod a couple weekends ago at the track.
Sorry you had the problem. |
Joseph Mills |
Nov 29 2004, 08:01 PM
Wow! 7 out of 8 of you nailed it!:trophy:
Driver's side inner CV joint! All of you have braggin' rights as far as I'm concerned! (IMG:style_emoticons/default/biggrin.gif) The very next time my car breaks down, I'm going to PM each of you for help! (IMG:style_emoticons/default/rolleyes.gif) Like George said, it was a good thing it happened at home. Another good thing is that a guy I don't really know that drives a miata/V8, immediately walked up and offered to use his rig to trailer my car home. That cheered me up. When I looked at the CVs, everything looked "normal". I thought when they go away, they actually detach themselves. So evidently that's what happens later? Okay, what do I owe everyone? (IMG:style_emoticons/default/biggrin.gif) |
skline |
Nov 29 2004, 08:06 PM
Considering you are in Oklahoma, nothing tangible, just get it fixed and get out and drive. Having another car on the road is all the thanks we need.
mightyohm |
Nov 29 2004, 08:12 PM
QUOTE(joseph222 @ Nov 29 2004, 06:01 PM) When I looked at the CVs, everything looked "normal". I thought when they go away, they actually detach themselves. So evidently that's what happens later? Usually the whole axle falls off on the inboard end because the 4 bolts holding it on back out. I'm surprised you actually broke a CV joint. That hasn't happened to me yet. (IMG:style_emoticons/default/biggrin.gif) |
Pesky 914 |
Nov 29 2004, 10:06 PM
Newbie Group: Members Posts: 42 Joined: 22-March 04 From: About to pass you... Member No.: 1,835 |
QUOTE(jkeyzer @ Nov 29 2004, 06:12 PM) QUOTE(joseph222 @ Nov 29 2004, 06:01 PM) When I looked at the CVs, everything looked "normal". I thought when they go away, they actually detach themselves. So evidently that's what happens later? Usually the whole axle falls off on the inboard end because the 4 bolts holding it on back out. I'm surprised you actually broke a CV joint. That hasn't happened to me yet. (IMG:style_emoticons/default/biggrin.gif) You need more power! I broke 2 with my 236rwhp modified 3.2L (IMG:style_emoticons/default/smile.gif) |
redshift |
Nov 29 2004, 10:39 PM
Breaking a cage is a good one! It happens when you get down make squeek.
Axelicus Flopicus, Anno Duo Dia, Corpus Cristi, Ass Dominos... M |
redshift |
Nov 29 2004, 10:42 PM
My most catastrophic failure was the inside left on a tightening right hand sweeper at 105.
That thing turns into a hammer, and destroys anything it touches, until, Allah willing, the outside one shears.. Uhhgg... (IMG:style_emoticons/default/icon8.gif) whoa... I just threw up in my mouth.. oof... M |
Joseph Mills |
Nov 29 2004, 11:15 PM
cametal |
Nov 29 2004, 11:20 PM
autox'n Group: Members Posts: 76 Joined: 28-July 03 From: Oklahoma City, OK. Member No.: 960 |
Hey Joseph, sorry to hear that. If you need a hand let me know. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 09:45 AM |
