FS -misc 914 parts - more added 9/3 - Revised prices, More and more parts coming out of the woodwork |
BS Chairman |
Jul 10 2013, 05:50 PM
Member Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 |
FS misc 914 parts - Revised prices
Newest Items Late Dash - VGC has one delaminiation at the corner of the left side gauge pod - $250 See Below Rocker Panels - See Below Windsheild gasket- See Below Blasted and painted trailing arms w/hubs- See Below Many newer items listed below. 1.8 FI computer $25 was running when switched to carbs L&R A Pillar cover w/plugs $25 Splash pan for under car. Blasted, painted, has some pits, tabs good $50 Door switch with gasket $5 Center/3rd Seat - Plastic tray decent, cracked hole. Center pad is solid, vinyl good $55 Early gauge set with silver buttons. Trip ODO unknown. $100 Headlight Motor Covers (pair) $20 no cracks Hood cable and pull - chipped paint - no key = $5 Ignition cylinder lock w/key we think it's late 71-73 - $5 Side marker Lens, crack on top - free with other purchase Side Targa Strip, the ones on the top, not the rear strips - so/so condition $5 Defroster vents -later cars w/center defrost $10 Will give discount for multiple items All items are plus shipping I take PayPal Attached image(s) |
KENNY |
Jul 10 2013, 07:11 PM
Member Group: Members Posts: 142 Joined: 5-February 03 From: Orlando fl. Member No.: 243 Region Association: None |
I will take speaker
BS Chairman |
Jul 10 2013, 07:56 PM
Kenny send me a PM for paypal address
Gary |
jim_hoyland |
Jul 11 2013, 07:07 AM
Get that VIN ? Group: Members Posts: 9,418 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I'll buy the hood pull/ cable. PM sent
JeffBowlsby |
Jul 11 2013, 01:20 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I will take this assembly. Total shipped to 94583 and payment details please. email or PM me.
Attached image(s) |
BS Chairman |
Jul 11 2013, 05:59 PM
Steering Wheels 2 types - BOTH SOLD and SHIPPED
Wheel 2 - 70-71 - uses long horn button feeler/extension - $65 Both wheels have minor nicks/scratches. No chunks or gouges missing Horn pads in good/VGC Attached image(s) |
BS Chairman |
Jul 11 2013, 06:02 PM
A Arms and cross member - Just blasted
Selling for cost of blasting plus $10 A Arms - $60 pair - Sold - Shipping 9/5 Cross Member $35 - Sold - Shipping 9/5 Can put a light primer or paint (rattle can) on prior to ship. Attached image(s) |
BS Chairman |
Jul 11 2013, 06:04 PM
MPC wire harness with unknown FI box
Harness has good soft boots, and is not brittle FI box is included NC $125 plus shipping Attached image(s) |
BS Chairman |
Jul 11 2013, 06:13 PM
Misc Items
Front Turn signal housing with crappy lens. The electrical contacts on this housing is good and the inside finish of the reflector is in great shape. Exterior has undercoating and road grime - $75 1 Pair Early window cranks - chrome has some pitting - $30 pair Early metal interior door pull with plastic insert $25 Left Side Tail Light housing - $25 Exterior housing has no cracks or heat blisters - has overspray on interior reflectors. Stud from tailight broken off and left in housing. Purchaser will have to remove knob/stud Rear Struts and Springs - NOT KONI or BILSTEIN - No manufacturer marking on strut. SOLD Attached image(s) |
BS Chairman |
Jul 11 2013, 06:18 PM
CV Joints, Axles, Boots and stub axle.
What can I say Blasted and painted stub axle and half shaft New boots CV joints are tight and grease free Pulled one apart to inspect - see photo Other one was not opened up for inspection Click on photo for larger view $225 per side $375 for pair Plus shipping Attached thumbnail(s) |
BS Chairman |
Jul 13 2013, 04:13 PM
Front door seal strips - $20 All plus shipping Attached image(s) |
billh1963 |
Jul 13 2013, 07:31 PM
Car Hoarder! Group: Members Posts: 3,403 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
I'll take the mirror
BS Chairman |
Jul 25 2013, 03:07 PM
From top left, down and then to right
Late model Jack Straps, good rubber - $10 pair (4) 2.0 wheel caps, crusty, dinged, $15 pair (2) headlight motor actuator screws $10 pair Side Shifter Transmission Coupler $30 Rear Trunk Top Latch Mechanism (plastic spacer has wear spot $25 (2) round relays - $10 each Shock Rubber (4) , spacer (2) and 2 caps - $10 Set Door stay $15 Koni Adjustable shock adjustment knob - $10 Rocker Panel Jack point covers $10 pair Cigarette Lighter $30 - Bezel is so so Bag of 5 Fllywheel bolts, Torqued once $10 Rubber covers for rear shock tower $12 pair Plus shiping Attached image(s) |
BS Chairman |
Jul 25 2013, 03:17 PM
7 25 bag B
Late Door Vent Plug with filter $5 L&R vent window gasket. Used but in good shape $20 pair Door handle Base - Flapper handle broken, Stud Broken, but could be drilled and tapped- No Keys $5 Early rear targa handle latch cover - Metal $20 Gold annodized heater tube clamps - $5 each VGC Attached image(s) |
BS Chairman |
Jul 25 2013, 03:22 PM
Chrome hub caps for early car - Decent chrome, rusting on back $5 plus shipping
SS Brake Lines - Unopened $30 set 2 NEW Sets front Brake Pads - $40 pair Attached image(s) |
BS Chairman |
Jul 25 2013, 04:16 PM
7 25 bag C
Nuts for Tail light lens, set 6 - $5 Rear Trunk Light, Good condition, no overspray $15 Rear Targa Latch cover - Late style, plastic $10 set Drivers side targa latch- Works, needs cosmetic - $20 Defrost Button and cover - $20 Metal 914 -- Fair shape, no broken pin - $20 Attached image(s) |
BS Chairman |
Jul 25 2013, 04:22 PM
7/25 Photo D
Rubber cover for headlight motor - good rubber $15 Door stays w/actuators $25 each SOLD Attached image(s) |
BS Chairman |
Jul 25 2013, 04:27 PM
Front Turn Lens - Good Shape, no crazing or scratches $10 All Plus shipping Attached image(s) |
BS Chairman |
Jul 25 2013, 04:33 PM
This one is a little weird, but, is it better to show your concourse car with a broken correct part or a new reproduction part? (IMG:style_emoticons/default/idea.gif)
1970 Hella backlight, with Chrome Outline and white switch $20 Yes, it is broken and someone did try to repair it. You be the answer to this question.... Attached image(s) |
Steve Snyder |
Jul 25 2013, 04:46 PM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
Dibs on the late tool kit & lug bolts, PM sent.
Lo-Fi Version | Time is now: 27th September 2024 - 08:36 AM |
