Media Blasting Question |
EdArango |
Nov 20 2013, 01:48 PM
914 Enthusiast Group: Members Posts: 267 Joined: 30-January 10 From: Huntington Beach, CA Member No.: 11,309 Region Association: Southern California |
Hi Everyone,
What can I expect to pay to get me roller tub media blasted? The car will be stripped without any lids. I assume it'll still have doors. Thanks!! ED (IMG:style_emoticons/default/confused24.gif) |
jimkelly |
Nov 20 2013, 02:05 PM
probably depends on your location to some extent.
http://www.914world.com/bbs2/index.php?sho...p;hl=sand+blast nothing prettier than a sweet little - 914 - getting her body blasted. (IMG:http://www.914world.com/bbs2/uploads_offsite/a8.sphotos.ak.fbcdn.net-1110-1300718427.1.jpg) |
bandjoey |
Nov 20 2013, 02:17 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
$750 in Big D
MBowman325 |
Nov 20 2013, 03:04 PM
Member Group: Members Posts: 465 Joined: 14-July 05 From: Oklahoma City, OK Member No.: 4,413 Region Association: Southwest Region |
I attempted to hit up a place here in OKC that does dry ice blasting. If I can get an answer from them I'll post it.
MBowman325 |
Nov 20 2013, 03:48 PM
For what it's worth, finally got a hold of one of the companies that does the CO2 blasting and he said it doesn't work well for paint stripping. I'd previously heard that tossed around as an alternative to soda and sand blasting, but I suppose perhaps not. (He quoted a half day job running 5-$600 though)
r_towle |
Nov 20 2013, 04:48 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
We had a 356 done on our site with a portable rig.
We used soda, not sand. It was 500 bucks |
Jon H. |
Nov 20 2013, 06:45 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
To save some cash and minimize panel warpage you could DA sand your flat areas and get the insides and underneath blasted. This is how the reputable restoration shops in my area told me they would do it. Cost with epoxy primer was approx $1200-$1300. It will be cheaper though because I will DA sand myself. The warpage issue I refer to is using sand as a medium?
Jon |
pcar916 |
Nov 21 2013, 05:23 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
ww914 |
Nov 21 2013, 09:13 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Hi Everyone, What can I expect to pay to get me roller tub media blasted? The car will be stripped without any lids. I assume it'll still have doors. Thanks!! ED (IMG:style_emoticons/default/confused24.gif) Whatever you do, do NOT attempt it yourself. I did just the engine compartment a couple of years ago and am still cleaning sand out of every area back there. |
CptTripps |
Nov 21 2013, 01:57 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I'm having mine soda'd in a few weeks after I finish stripping everything out of it. There's a local guy here that'll come to me (or wherever the car is) and do it for $650. I'm going to have it on a rotisserie so the whole thing in/out gets done at the same time. I'll have it epoxied about 2-3 hrs later after the body shop power-washes the tub and bakes it for a few hours in their paint booth. We thought that'd be the best way to dry it all out after the soda and wash.
strawman |
Nov 22 2013, 05:45 PM
Senior Member Group: Members Posts: 883 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I also DA sanded flat panels to save blasting time. I'll add that blasting doesn't do a good job of removing the seam sealer. I scraped mine out with wood chisels, awls, screwdrivers and everything else possible to dig that crap out. It is amazing how much rust can be hidden underneath that stuff. Then I blasted the corners and uneven surfaces, followed by epoxy primer.
My back still thanks me for using a rotisserie for that work... |
PanelBilly |
Nov 22 2013, 06:49 PM
914 Guru Group: Members Posts: 5,840 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
The guy who did mine said he wouldn't do the underside of the hood and trunk. those areas wern't bad anyways. He said that it would hurt the top surface. Mine was walnut blasted and then primed. Cost somewhere around $1000. I spend days with the airgun and vacuum cleaning it out before he did the prime. I knew that I was going to take my time on the body work and didn't want it to rust because the surface was exposed.
X911IC |
Nov 22 2013, 07:44 PM
Member Group: Members Posts: 81 Joined: 17-June 13 From: California Member No.: 16,026 Region Association: Southern California |
This guy is a little far away from you but does a lot of cars and I have been very happy with his work.
Freddie @ A and M Sandblasting, 9344 Oso Ave, Chatsworth, CA 91311 (818) 727-1865 No harm in checking. I think he wanted $800 to do my car. |
Eric_Shea |
Nov 23 2013, 11:35 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We do soda unless there's rust. No way these things will hurt the top of the metal, especially walnut.
$700.00 |
Lo-Fi Version | Time is now: 27th September 2024 - 09:05 AM |
